Can I tell 1.5 vs 1.6 roller rockers from measuring?
Old 04-06-2002, 01:28 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I have some aftermarket aluminium boxy shaped RR's of unknown ratio.
Across the top they measure 2.75 inches total. From the pushrod end to the center of the stud hole they measure 1.25 inches. From center hole to rocker end they measure 1.5 inches.
Anyone know the ratio.
Old 04-06-2002, 06:20 PM
Aaron91RS's Avatar
Car: RS
ttt
Old 04-07-2002, 01:16 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
My Crane's are stamped right on the top and I thought all manufacturers stamped them on there somewhere. Maybe I'm wrong though
Old 04-07-2002, 01:20 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Measure center hole to the push rod end. If that's 1.5 as well then I would say they are 1.5 roller rockers. I know with 1.6 you have to elongate the push rod slot so I would assume the cause of this is a 1.6 inch measurement from center hole to push rod end.
hectre13
Car Audio
26
03-03-2022 05:38 PM
KO1
16
10-15-2015 05:00 PM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
dusterbd
09-29-2015 08:40 AM
tcarlos13
Interior Parts Wanted
09-28-2015 06:31 PM
Quick Reply: Can I tell 1.5 vs 1.6 roller rockers from measuring?
