Heater Hose?? I searched & searched
Old 03-27-2002, 10:15 AM
formula88bird's Avatar
On my 88 (LO3) where does the heater hose go that curves down from the heater core go? I need to replace it when I change out my Heater core. Do I need to jack up the car to remove the lower end of the hose or what? Pics would also help. Thanks in advance for any help that you can provide for me.
::hail: You guys ROCK
Old 03-27-2002, 10:25 AM
SSC
SSC's Avatar
Car: No more birdy
Your car should have a 5/8 heater hose that goes into the intake manifold behind the alternator and a 3/4 hose that either attaches to the water pump (early model) or goes into the radiator just above the upper transmission cooler line. Your 3/4 hose should go to the radiator since its an 88 but if some one replaced the radiator plug it into the water pump.
Old 03-27-2002, 10:44 AM
I have thet heater control valve thing. I have a total of 5 hoses.
1. back of manifold to control valve,2. heater core to control valve,3. control valve down to a metal pipe,4. metal pipe to radiator,5. heater core to where??? and how do I get to the lower hose clamp???
Formula8r89
09-22-2015 04:24 PM
Stryker412
09-20-2015 06:59 PM
BWilcox
09-20-2015 12:19 PM
st.evel07
09-19-2015 09:24 PM
BOOT77
09-16-2015 08:37 PM
Quick Reply: Heater Hose?? I searched & searched
