how to tell a 305 tpi from a 350 tpi???
Old 03-22-2002, 11:10 PM
Don_89Iroc's Avatar
how can you tell a 85-91 305 TPI car from a 350 TPI car, can you tell bye just looking at the motor or do you have to have the vin number??? im asking because my car is a 5.7 TPI and his T/A is a 305 and the A/C and the alternator are on different sides on his car than mine and he says that some 350's have the A/C on the same side as his car does thanx for your help
Old 03-22-2002, 11:33 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
No, the only way to differentiate between the two engines via the eighth digit of the VIN number, besides crawling under their and getting the casting numbers off the block or the heads. This is if the engine is stock of course. If its an L98 (350), it will be an "8". If its an LB9(305), it will be an "F". The location of the A/C compressor won't tell you because all f-bodies had the A/C compressor relocated to the passenger side i believe in 87 or 88 to "unclutter" the engine bay (didn't work).
Old 03-23-2002, 12:13 AM
BobbyK's Avatar
Car: 71 BLAZER
Engine: SBC 350
Transmission: TCI 700R4
Axle/Gears: 12 bolt with 3:73's
Didn't the connections to the fuel rails differ.Wasn't the 350's fuel rail connection point on the passenger side of the eng. and the 305's connection point went from the passenger side down and across toward the drivers side of the block?
Old 03-23-2002, 12:31 AM
whiteroc's Avatar
The only differing TPI fuel rail set-up would have been with the Corvette. The 305 and 350's external engine parts were all the same except for the injector sizes and a different knock sensor.
Besides the VIN"8"&"F", you can tell the size of the original motor by the sticker under the original hood - will read either 5.0 or 5.7.
Old 03-24-2002, 07:20 AM
Frank88's Avatar
I resolved this question on my car (which although it came with a 305 supposedly had been swapped out for a 350) by pulling the driver side valve cover and reading the head casting number. Mine is a 350! Confirmed by injector part # also, although these are very difficult to read.
350 = 14101083
Old 03-24-2002, 07:49 AM
Want a title? Post!
JWZ28's Avatar
I pulled an 87 TPI motor out of an 80 Cutlass and saw on the back of the block a casting mark which read '5.7'. That's pretty hard to say it's not a 350 motor! HTH
Old 03-24-2002, 11:48 AM
360Iroc's Avatar
you know some people use 305 injectors on 350's
Old 03-24-2002, 10:35 PM
bigals87z28's Avatar
Car: Check The Sig
hey another way is that if u look under the glove box cover u will see a sticker with all the RPO codes u can look for LB9 or L98 i always wanted to know what they put in my car.. my dad said that some time after he bought the car he found there was a crack in the block... but it was covered by waranty but maybe just maybe they mixed it up and didnt put a 305 back in but put in a 350!! nahh couldnt get that lucky... maybe.... hehehe
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
bamaboy0323
08-15-2015 07:20 AM
wruiz
08-13-2015 09:07 PM
gta power
08-13-2015 06:15 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: how to tell a 305 tpi from a 350 tpi???
