Will broken rocker arm cause "clacking" noise?
Old 03-10-2002, 07:11 PM
MrsLottaBallsCamaro's Avatar
Would a broken rocker arm cause a clack clack clack noise? My RS is making that noise, and among other things, we were thinking it could possible be a broken rocker arm, but we aren't sure. I was thinking that if it was for an exhaust valve, and the valve won't open, it might make a sound like that...........maybe..........I really don't know. Please help me!
Old 03-10-2002, 07:20 PM
Joshua Leslie's Avatar
hey..
*** bless any and all countries, and the people that reside in them.
yeah, the noise could be from a broken pushrod, which can and will make the rocker arm smack against the valve cover. this happend 3 times to my89. turned out I had the wrong rockers.
You will usually be able to feel the rocker hitting on the VC with your hands,just put them on the VC, you will feel a steady smacking.
Also, if you have managed to break a rocker or pushrod, you will most likely have a severe miss.
Old 03-10-2002, 08:00 PM
Blackened's Avatar
Another possibility is that you pulled a stud... again.. causing the rocker arm to be VERY loose. Dont drive it like that... fix it !
Hotrodboba400
12-10-2019 07:07 PM
TX-SleeperC5
02-24-2016 01:34 PM
New2Chevy
09-28-2015 12:35 AM
ericjon262
09-11-2015 06:07 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Will broken rocker arm cause "clacking" noise?
