TPI 350 engine specs
Old 03-06-2002, 02:34 PM
KYL98's Avatar
Car: 1991 Z28
I was wondering if anyone knows where I can find engine specs for the L98? I am planning a cam and head swap very soon, and I was wondering where I could get some info on that motor. I have some stock cam info, somebody please check this for accuracy please.....
Lift .413 INT .428 EXH
Duration 202 INT 207EXH
Lobe seperation 114.5
rocker arm ratio 116/116
I was also curious who makes the best intake runners? And finally, If I get say, Edelbrock heads, will I have to port match the intake for them to fit? Any additional info would be GREATLY appreciated. Thanks guys...
Mike Estep
Old 03-08-2002, 11:05 AM
tpi_roc's Avatar
Re: TPI 350 engine specs
Mike Estep
Rocker arm ratio is 1.5:1 :P
SLP makes the best runners IMO because you can always go siamesed with them later. Your cam specs are close enough, a degree or two off on duration is no biggy, LSA is 114, lift is about what you said, maybe a little more.
Vintageracer
01-10-2020 05:33 PM
NinjaNife
08-23-2015 11:49 AM
st.evel07
08-13-2015 06:15 PM
85Iroc-Z
08-13-2015 01:58 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: TPI 350 engine specs
