a 350 bored .040 over equals what?
Old 02-26-2002, 10:43 PM
fattie92's Avatar
what is a 350 that is bored .040 equal to? 355 or a 358?
Old 02-26-2002, 11:11 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
Old 02-27-2002, 01:55 AM
rezinn's Avatar
.03 overbore is approx. 5 cubic inches. .040 is almost 7
Old 02-27-2002, 08:50 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
((Pi * (bore/2)^2) * 3.48) * 8
For a standard 350:
((3.14 * 2^2) * 3.48) * 8 = 349.67
For a .030 over 350
((3.14 * 2.015^2) * 3.48) * 8 = 354.94
For a .040 over 350
((3.14 * 2.02^2) * 3.48) * 8 = 356.70
For a .060 over 350
((3.14 * 2.03^2) * 3.48) * 8 = 360.24
Old 02-27-2002, 01:49 PM
fattie92's Avatar
thanks guys.
Old 02-28-2002, 08:14 AM
Vader's Avatar
For a standard 350:
For a .030 over 350
For a .040 over 350
For a .060 over 350
Actually, that is very close. If you take the value of out to more decimal places, the numbers start coming up a bit different, but round to about the same. 0.030" overbore will net a 355.1 CID.
If you want a "cheater" spreadsheet, check this link:
Engine Calculator.xls
Old 02-28-2002, 09:27 AM
Mark305TBI's Avatar
C'mon Vader, quit being so nit picky. It was alot easier to just type 3.14 and our calculated volumes are within 1%. Everybody's going to round up/down to the nearest cubic inch anyway...
Old 02-28-2002, 10:50 AM
82camaro's Avatar
Car: 82 camaro SC
Vader has it right though. To do it correct you should only round the final value. Rounding values used in the formula then rounding again won't be as accurate.
Old 02-28-2002, 11:07 AM
Mark305TBI's Avatar
Well, technically, anytime you use Pi in an equation you have to do some rounding. How much rounding depends on the desired accuracy you wish to get from your calculations. Since we only wish to get our calculated values correct to one cubic inch it doesn't really hurt to only use Pi out to two decimal places...unless you just want to be nit picky for the fun of it.
Old 02-28-2002, 10:04 PM
Nordbert's Avatar
I like this one : Bore x Bore x .7854 x Stroke x # of Cyls.
Example: 4.001 x 4.001 x .7854 x 3.48 x 8 = 350.02348
Hotrodboba400
12-10-2019 07:07 PM
89-S-dime
Southern California Area
09-04-2015 10:34 AM
Strick1
09-04-2015 07:11 AM
Formula_88AE
09-03-2015 01:47 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: a 350 bored .040 over equals what?
