Can i scrap the MAF?
Old 02-07-2002, 03:50 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Can i scrap the MAF? I took out the screen to the MAF yesterday and it worked fine for a few hours. I got a code 34 and giggle the wire a lttle and it turned off. Again this morning code 34. But this afternoon service engine light. I knew the concequences when i took the screen off that if something got in there it could mess with the sensor. I was wondering if i could just put a pcv pipe in the place of it. Does the ECM need the input from the MAF Sensor?
Old 02-07-2002, 03:56 PM
Blackened's Avatar
Sure you can take it out. GM put that 300 dollar MAF sensor in there just for good looks. Doh! Go get a new one!
Old 02-08-2002, 09:39 AM
Vader's Avatar
Stuart,
Yes, the ECM absolutely needs a signal from the MAF to be able to meter fuel correctly.
This is not intended as any kind of lecture, but if you do some rudimentary math you would discover that removing the MAF screens on a 173 CID engine doesn't provide any real benefit since the MAF is not really a restriction.
Your ECM should be cleared of all error codes by disconnecting the battery for about five minutes. Once it is cleared you can try running the engine again to see if the error code repeats. Until you clear the stored codes, the previous error code will remain in memory for the next 50 engine start/stop cycles.
You should verify that the MAF electrical connector is clean and tight, and seated correctly. Make sure the intake tract and ducts are sealed so there are no leaks around the MAF. If the code repeats after this, you may need a replacement MAF. I would suggest checking into the Wells/Conrad replacement, since it uses a thick-film sensor instead of the frail hot wire. There is only one "screen" in front of the sensor, and it is really a flat metal matrix instead of a round wire screen, so the restriction is very minimal. These replacements are lifetime warranteed, and are about $180.00 instead of $300.00 plus from GM or the rebuilders. For my money, and remanufactured hot-wire unit is a waste of resources.
Mark_ZZ3
05-24-2018 01:02 PM
BumpaD82
02-26-2016 02:57 PM
92projectcamaro
12-08-2015 12:25 AM
racereese
10-03-2015 03:46 PM
Quick Reply: Can i scrap the MAF?
