Whats the widest tire i can put on my thirdgen camaro
Old 02-03-2001, 07:08 PM
vortech305's Avatar
I have a 92' camaro with drum brakes in the rear. I plan on ordering SLP's ZR1 rims which go for $700 dollars and thats a good price. The rims are 17x9.5 and 275's seem good but whats the widest i can go without the tire sticking out of the fender or hiting the firewall Please specify the size of the backspacing for each tire size u name
Thank u very much
Old 02-03-2001, 07:17 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
search the archives , this has been covered
Old 02-03-2001, 09:35 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I have those wheels Check my signature for pictures. I used 275's out back with 1.25" spacers and 255's up front with 2.25" spacers. I am having a problem with wheel rubbing on the front wheel well. It developed about 2 months after I put the wheels on but only on sharp turns. It ripped out the fender liner and after that came out the tire will actually caught the lower corner of the fender itself and it bent the hell out of the fender. I have no idea why this happens. If I had gone with the 275's up front I would have been totally screwed so thats something to think about. But there are others using 275's all around with no problems.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old 02-03-2001, 09:41 PM
89ProchargedROC's Avatar
get a 4th-gen rearend for some extra room. beat on the inner wheel well, and go get some 17 x 11 w/ 6.5" of backspacing and put on those 315's
Old 02-04-2001, 02:17 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
With a little banging on the inner fenderwells, I fit some 295/50R15 in the back. I have the stock, second gen turbo wheels. I think that they are 15x8. They have a nuetral offset. (none) Meaning that I have 4" of backspacing. Nothing changed when I swapped rears.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old 02-04-2001, 05:50 PM
vortech305's Avatar
thanks for replying everyone so i guessing i can use 295/40/17? sorry im a little incompetent today.
Old 02-06-2001, 08:28 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
you can probably use the 295's out back but you may need a different spacer size.
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Old 02-06-2001, 01:04 PM
Black Beauty's Avatar
Car: 90 Camaro RS
i agree with 89PRO throw the 315s on that baby....
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old 02-08-2001, 05:14 PM
Chad91Rs's Avatar
315/35/17's will fit.
Myself and a few others have them.
You need 6" of offset for them to clear the inner most contact point after you hammer them out a bit.
If you stay with either a 15" or 16" rim you can go with a 295. They look damn good as well and I'm sure they hook up better than a 245.
Old 02-08-2001, 08:56 PM
Superblue87Formula's Avatar
<font face="Verdana, Arial" size="2">tire sticking out of the fender or hiting the firewall </font>
if your tires hit the firewall, you've got big problems!
Frozer!!!
01-19-2024 04:55 PM
mitch_04
Members Camaros
20
09-20-2021 02:24 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
Exxon Limited
08-09-2015 08:13 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: Whats the widest tire i can put on my thirdgen camaro
