Holley vacuum leak, base plate
Old 01-07-2002, 10:29 PM
jamesbern's Avatar
I know that this is really a cheap mans problem, but I don't get my new carb until at least next month. My carb has a vacuum leak between the base plate and the body of the carb. Is there any way to seal it if a new gasket doesn't work. I don't want to spend too much more on this old beater carb and a little riggin to get me by until Feb. is fine.
Old 01-08-2002, 12:52 AM
Jester's Avatar
Depends on what causing it. Maybe the gasket is damaged and replacing it will fix it.
I had the same problem and found that I'd stripped out the baseplate screws on one edge. I drilled and retapped it to a larger size, and used allen head bolts instead.
if the baseplate is warped..you can try doubling up the gasket and over torqueing the bolts...but you may be screwed.
Old 01-08-2002, 07:11 AM
jamesbern's Avatar
I'm probably screwed knowing my luck this week, but I will try doubling up the gasket. I thought that two gaskets might help, but wasn't sure if there was any better way to fix it. Thank you!
Old 01-08-2002, 08:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
separate the baseplate and main body.
Where ever the gasket is torn or questionable
apply some "Seal ALL", wait about 20 min and
reinstall ... The stuff fixes any thing and is not affected by gas.
Look for it in auto parts stores.
Old 01-08-2002, 09:20 PM
jamesbern's Avatar
thanks!!
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Infested
05-22-2018 11:56 PM
bamaboy0323
09-03-2015 06:07 AM
cstrobel65
08-15-2015 10:19 AM
Quick Reply: Holley vacuum leak, base plate
