Installation Question... Where does the orange wire go?
Old 11-23-2000, 09:53 PM
voltran's Avatar
I'm gonna install my new cd player tomorrow. (By the way I ended up getting the Pinoeer DEH6200 ) There is an orange wire that says "lighting switch terminal". Where does it go in the car? I have 2 wires inside the car. One is brown for illumunation and the other is gray for dimmer. I assume it goes to one of them. But which ?
Old 11-23-2000, 10:25 PM
Neo
Neo's Avatar
I just installed my CD player (Clarion) last week and I just wired those up and did not connect them to anything, I did the same for the one that goes to my power anntenna.
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube in back
Future: 2" Cowl hood w/ K&N filter
Old 11-24-2000, 01:49 AM
voltran's Avatar
You mean you didn't connect the orange wire (from the unit) to anything ?
Old 11-24-2000, 04:23 AM
Omar's Avatar
It goes to your brown illumination switch. When you turn on your lights, it turns on additional lights on the deck, and on some decks, the dimming function kicks in since you are telling the deck it is dark outside. On my past Pioneers, I liked ALL the illumination to ALWAYS be on when the deck was on, so I wired it with the remote wire (used to be blue).
1989 IROC-Z 5.7L
Old 11-24-2000, 08:31 PM
voltran's Avatar
Hey,Omar. I didn't get what you're saying.
When you want all the lights on the deck you connected the orange wire to the blue one ?
Old 11-24-2000, 11:21 PM
Chris Luongo's Avatar
If you want your radio to stay at full brightness all the time, don't hook the orange Pioneer wire to anything.
If you do want the radio to dim down when your headlights are on at night...I think you'd hook it to the brown illumination wire...but try each wire to see if one gives you a better result.
As always, cap or tape any wires that you decide not to use. And I sure hope you're using a wiring harness adapter and not just cutting up your car's wires.
Old 11-26-2000, 02:53 AM
voltran's Avatar
Thanks Chris. That's all wanted to know. So leave the orange wire alone for the full illumination......
rocn7roc
09-21-2021 02:16 PM
89GTAOz
05-16-2020 09:31 AM
Caspar
06-19-2016 11:19 PM
Ikes 91Z
12-09-2015 03:49 PM
tnrednneck
08-13-2015 08:57 AM
Quick Reply: Installation Question... Where does the orange wire go?
