TH-400 Driveshaft: Slip Yoke or Remote?
Old 11-20-2013, 09:06 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
So swapped a turbo 400 in that came out of a truck (has the bolt on yoke). I was about to order a driveshaft from Denny's that has the special slip yoke with the counterbore that corrects for the difference in the output shaft on the truck 400s.
My brother works for a part place in CT, and he talked to his "driveshaft guy" who has been "making drive shafts for xxx number of years", and he says a remote slip joint in the driveshaft and retaining the bolt in yoke is the better way to go. He also says the counterbore yoke "doesn't work", which kind of ruins his credibility for me because I've read about plenty of people using it.
I personally think its a stupid idea, but I was curious what you guys had to say about it. My dad seems to be on board with the other idea too, and I can't understand why. Can anyone tell me some kind of advantage to this?
Old 11-20-2013, 11:03 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: TH-400 Driveshaft: Slip Yoke or Remote?
The third gen driveline is relatively short, so there's no reason to consider going to an alternate style or multi-piece driveline. Also, the suspension travel isn't a huge amount, so the standard short passenger car TH400 yoke length in the conversion yoke is absolutely fine.
With regard to doing a slip joint elsewhere in the driveline, the further away from the ends a joint is placed, the more likely it is to develop a wobble.
Any added diameter to the driveshaft has the torque arm to stay clear of.
And a remote slip is going to make for a slightly heavier driveline than a one-piece tube + two yokes.
Trucks are a little better off with the remote slip because with taller tires, lower driveline rpm is achieved and critical speeds aren't going to happen with tire heights (that would never tend to be run on a third-gen.) They need a longer amount of slip motion because of a greater amount of suspension travel.
On a third gen with ~26" tires and 3.73 gears, you should try and keep the driveline light and simple.
In short, yeah it works in millions of trucks just fine. But in the case of the third-gen, there's zero benefit, and added complexity in what he's suggesting. Denny's will take good care of you.
Old 11-25-2013, 01:14 PM
Car: 1984 Trans Am
Thanks jmd, that's what I figured. I emailed Denny's my concerns, and they were very helpful. Basically, they said either would work, but for any kind of performance, the slip yoke is the way to go.
So thank you, I'm going with Denny's. Anyone else in a similar position, I would recommend them.
Old 11-25-2013, 08:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You don't need a 2 piece driveshaft under a third gen. Just buy a TH400 slip yoke and get a driveshaft made for the proper length once you know where the yoke will be in the transmission.
It doesn't hurt to upgrade everything to 1350 u-joints now. Tranny and diff yokes then when you get a new driveshaft, get 1350 weld ends installed.
Old 11-26-2013, 01:19 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
when they did mine they machined the output shaft in the trans. you can just modify the yoke?
Old 11-26-2013, 02:19 PM
Car: 1984 Trans Am
Yeah. The quote from Denny's is that "Denny designed this yoke 25 years ago and it's been used successfully and without complaint by thousands..." yada yada.
Obviousily the supplier is going to tell you that, but some research on other forums (Chevelle and a general hot rodding one) seems to confirm what Denny's told me. It stands to reason that if you can modify the output shaft, the same can be said for the yoke.
Old 11-26-2013, 03:24 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
they were taking my trans apart to rebuild it anyway so doesnt much matter, i was just curious because i havent heard of doing it that way before
Old 05-08-2020, 05:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Replied to wrong thread.
nowerelsetoroam
02-13-2013 05:17 PM
fireredz28
01-31-2010 03:22 PM
steve87iroc
06-02-2007 06:07 PM
Quick Reply: TH-400 Driveshaft: Slip Yoke or Remote?
