[MI] 1988 Camaro 5.0 TBI, Auto Part Out
Old 08-19-2013, 09:38 PM
Dan Hubbard's Avatar
Car: K-1 Evoluzione (85 Camaro)
Engine: 5.7L
Transmission: TH700R4
Axle/Gears: stock
1988 Camaro Z-28 with 305 TBI engine, auto-trans, TH 700R4. Odometer read 17xxx miles. Assuming that's 117xxx miles. Teardown is complete and carcass has been scrapped. Let me know what parts you need. Shipping service is available for smaller parts with payment through PayPal.
Parts from '88 Camaro:
Fenders. Left and Right, in nice condition. 1 small rust patch on left fender
SOLD!! High-mounted 3rd brake light.
Hatch support springs/gas springs
Wiper arms, blades, and wiper transmission
Wiper motor
Ground Effects. Some damage to underside portions (not visible when installed)
Dome light
Driver side door panel. Nice shape. Top edge is cracked near mirror. Repairable.
Fuel door and surround. Very nice condition
SOLD!! Fuel pump, and sending unit. Everything works.
Engine. Throttle body 305 with all accessories.
Engine harness and ECU.
Transmission. TH700R4
Heater pipe
Windshield washer reservoir and pump
Power steering cooler
Fuel lines
Evap. cannister
Wheel house liners (3)
Rear hatch lift support gas springs. Good shape, holds up hatch no problem
Headlight wiring harness, complete and uncut.
Brake booster, Master cylinder, and Proportioning valve
A/C condensor, with rubber pads, foam cushion
Heater core, blower fan motor, complete.
Throttle Cable
Transmission kick-down cable
Cruise control cable, actuator, and vacuum reservoir
Cruise control wiring harness, complete and uncut
Speedometer cable
Park brake handle with cover
Interior trim panels. Grey.
Passenger side door sill plate.
SOLD!! A/C evaporator core module
SOLD!! Hatch pull-down motor.
SOLD!! Dash cluster (standard gauges)
SOLD!! Dash/Interior harness complete.
SOLD!! Doors.
SOLD!! Hood.
SOLD!! Hatch. Very nice condition.
SOLD!! Hatch seal
SOLD!! Console. Very good condition. Console lid is really nice.
SOLD!! Auto Shifter
SOLD!! Hood hinges with gas support springs
SOLD!! Hood release cable and interior handle
SOLD!! A/C wiring harness, complete and uncut
SOLD!! Shifter Cable
SOLD!! Driveshaft
SOLD!! Sail panels (rear speaker covers). ABS plastic backing. Grey.
SOLD!! Seat belt set, Grey.
SOLD!! Exhaust system. Complete from engine to tail pipes.
SOLD!! Shift ****
SOLD!! Shift Interlock Cable
SOLD!! Steering Column. Complete tilt column with key, wheel, multi-function switch.
SOLD!! Tail lights. Excellent condition
SOLD!! Seats. Driver seat is power, passenger is manual. Cloth. No rips or tears. Needs cleaned and that's all.
Previously listed 86 Firebird parts still available:
Interior parts:
Firebird, Camaro Power locks and lock switches
Firebird, Camaro Heater controls (AC car)
Firebird Rear Seats - good shape. Needs cleaning only. Black and grey.
SOLD!! Misc. Trim panels front and rear.
Exterior and Engine parts:
Firebird, Camaro Strut Tower Covers (black caps. inside engine compartment)
Firebird Rear Hatch, high-mounted 3rd brake light, and wiper (no wiper arm)
Firebird Wing-style spoiler
Firebird, Camaro Park lights
Firebird, Camaro Turn signals (front)
Firebird, Camaro Exterior door handles.
Firebird, Camaro Alternator
ECM for 2.8L MPFI engine
Radiator. 2.8L MPFI engine. Doesn't work with V8's
Firebird Radiator cover. Includes the rubber pads
Firebird, Camaro T-Tops, Left and Right. Good condition.
SOLD!! Firebird Air cleaner assembly (specific to Firebird and Trans Am, won't fit Camaro)
SOLD!! Firebird Hood. Twin vents in the front. Passenger side is missing its screen
SOLD!! Taillights. Center portion NOT included (I used it on my project car)
Attached Thumbnails 1988 Camaro 5.0 TBI, Auto Part Out-sam_0866.jpg   1988 Camaro 5.0 TBI, Auto Part Out-sam_0794.jpg   1988 Camaro 5.0 TBI, Auto Part Out-sam_0802.jpg
Old 09-12-2013, 08:32 PM
dennisschreuer's Avatar
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: 1988 Camaro 5.0 TBI, Auto Part Out
Hi Dan, i AM LOOKING FOR A SHEET METAL COVER THAT GOES FROM THE CORE SUPPORT TO THE NOSE OF THE CAR IN PLACE OF A TPI AIR CLEANER SYSTEM, THAT IS JUST UNDERNEATH THE HOOD.
DO YOU HAVE THAT?
cOST AND SHIPPING TO 91773 txS dENNIS
Originally Posted by Dan Hubbard
Just in, 1988 Camaro Z-28 with 305 TBI engine, auto-trans, TH 700R. Odometer reads 17xxx miles. Assuming that's 117xxx miles. Teardown started. Let me know what parts you need. Shipping service is available for smaller parts with payment through PayPal.
Hood. Flat hood, not louvered. Very good condition
Doors. Driver side is manual door, with some rust on lower inside edge, passenger side is power window, power lock and is in great shape.
Hatch seal
Auto Shifter
Driver side door panel. Nice shape. Top edge isn't cracked like most are.
Windshield. Excellent.
Engine. Throttle body 305 with all accessories. Still in car. Will pull soon.
Engine harness and ECU. Still in car. Will pull soon.
Transmission. 700R4 still in car. Will pull soon.
Driveshaft
A/C condensor
A/C evaporator core module, complete. Still in car. Will pull soon.
Shifter Cable
Throttle Cable
Shift ****
Park brake handle
Park brake
Dash harness. Still in car. Will pull soon.
Interior parts:
Old 09-12-2013, 09:16 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Hi what's the price for the engine harness also the console lid?
Old 09-12-2013, 09:49 PM
Engine: 5.7L
Axle/Gears: stock
Sorry Dennis. That part was too rusty and got scrapped with the car.
Old 09-12-2013, 09:50 PM
Engine: 5.7L
Axle/Gears: stock
Console lid got shipped to Italy, of all places! Asking $75 for the engine harness.
BRoss99
12-07-2020 06:50 PM
db057
08-22-2015 08:17 PM
InfinityShade
08-22-2015 08:00 PM
Leggman1
Brakes
08-12-2015 08:39 PM
1nastygta
08-08-2015 07:38 PM
Quick Reply: [MI] 1988 Camaro 5.0 TBI, Auto Part Out
