Door won't unlock from inside
Old 07-09-2013, 09:07 PM
cdoyle's Avatar
Hi,
This has be stumped.
The other day my lock on the inside will no longer unlock, but it works fine with the key.
I have the door panels off, and all the rods are connected. I can lock the door but when I try and unlock it, it almost acts like it's not pulling it enough. I can see the mechanism moving but it doesn't quite go as far as it does with teh key. With the key it works great, but on the inside I can pull that rod until the door collapses and it won't unlock. I can lock it from the inside, but not unlock.
Is the any type of adjustment on the mechanism itself?
Old 07-09-2013, 09:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Door won't unlock from inside
Try some silicone spray or even brake cleaner into the solenoid.Should free it up a bit.That worked for me some years back.
Old 07-09-2013, 10:07 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Whooa im sorry but may i ask what the hell is that on the back of your car? It looks sorta like a ram air hood style thingy but i cant figure it out, it does look cool though but what is it?
Oh and OP I have no clue why your door lock is doing that, i hae never heard of a door doing that before but maybe it's just worn out.
Old 07-09-2013, 10:09 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Also 84 1LE is there a back window there near where your head would be at while sitting? If there is then thats freaking awsome
Old 07-09-2013, 10:31 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Its a homebuilt decklid, yes, there is a back window.
Old 07-10-2013, 11:25 AM
cdoyle's Avatar
I'll give that a try, hopefully that works I really don't want to take any of it apart.
Roblyons
09-12-2015 10:29 PM
Out-Cast
08-23-2015 06:33 AM
g.l.mos
08-22-2015 12:02 AM
BlackTopKing
08-19-2015 12:13 PM
BrianI
08-09-2015 11:52 AM
Quick Reply: Door won't unlock from inside
