Small Diameter Power Boost
Old 06-22-2013, 11:43 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I am looking for a smaller brake booster for my car, does anyone know if one is made to fit our cars.
Old 06-27-2013, 06:06 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Small Diameter Power Boost
Thought about hydroboost?
Old 06-28-2013, 07:49 PM
572_Rat's Avatar
I believe they run from powersteering pump, I do not have one plus the only thing I am running is an alternator.
Is the fourth gen booster smaller then the 3rd gen
Old 06-28-2013, 10:25 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you won't find a smaller booster than the stock one... if it's taking up too much room, then figure out which master cylinder would work best in a manual setup and go that route.
Old 07-01-2013, 12:46 AM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
I need to get one too, I was looking at this one, anyone know if this would be good?
http://www.summitracing.com/parts/rs...maro/year/1988
Old 07-01-2013, 07:16 PM
572_Rat's Avatar
It says it is a 8 inch booster, I believe ours is a 8 inch as well, so It will not be any smaller
Jake_92RS
01-28-2020 10:37 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
toronto formula
11-10-2015 06:17 AM
InfinityShade
08-22-2015 08:00 PM
86White_T/A305
08-17-2015 12:16 AM
Quick Reply: Small Diameter Power Boost
