305 tbi to 350 tbi to vortec head swap..
Old 06-14-2013, 09:46 AM
andyvr4's Avatar
hi all thanks for the help in advance.
im headed to florida to get my 90 camaro rs 305tbi up and going again and my father and i are swapping the engine from a 90 suburban which is a 350tbi and was searching for what all is needed so far i know i need to swap over some parts and need a 350 ecm, anything else? and i was also wanting to do the vortec head swap i found some heads in the junk yard that are on a 97 1500 and was wondering what all needed to be done. ive searched high and low and have gotten told what to get but then told i didnt need them. so im confused. i know i need the vortec tbi intake, vortec heads, possibly the drivers exhaust manifold and tube, do i need to change the cam? what kind? should i just get the vortec cam and chip from the truck in the junk yard?
Old 06-14-2013, 10:16 AM
andyvr4's Avatar
Re: 305 tbi to 350 tbi to vortec head swap..
im going to be in florida this wednesday so help would be appeciated.
Old 06-14-2013, 07:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
what all is needed , need a 350 ecm, anything else?
A 350 TBI knock sensor
you only need a 350 chip for your ECM , not the whole ECM
Old 06-15-2013, 09:24 PM
andyvr4's Avatar
Any specific chip or just a 350 tbi 700 r4 chip?
Old 06-15-2013, 09:33 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...sion-prom.html
Old 06-16-2013, 10:09 AM
andyvr4's Avatar
Ok thank you. Anytjing else? How do I install it?
Old 06-16-2013, 10:19 AM
Engine: Lb9
Transmission: M20
You will need larger injectors atleast 55#hr, The prom is easy to install. Remover the two 1/4 screws holding on the access cover on the ecm. Remove the prom. If the prom is stuck you can gently pry under the prom holder tabs using the ecm for leverage one side of the prom alittle than the other side. The prom can only go in one way you will see its holder has different spacing on one side vs the other.
Old 06-16-2013, 05:33 PM
andyvr4's Avatar
Wow ya that is easy. Thank you. Is the 55 injectors on the 350 tbi already? Or do I get them from which vehicle?
Old 06-16-2013, 06:21 PM
Engine: Lb9
Transmission: M20
The 350 would have the 55#hr injectors.
Old 06-16-2013, 09:42 PM
andyvr4's Avatar
Ok thank you.
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
10-29-2022 09:20 PM
xkingcodex
02-12-2020 07:43 PM
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 305 tbi to 350 tbi to vortec head swap..
