1983 Cross Fire Injection CFI Fuel Line
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
I am replacing the fuel filter on a 1983 Z28 CFI and I need to replace the fuel line from the output of the fuel filter to the engine fuel intake. Does anyone know where I could find this line with the factory bends for a perfect fit, or an alternative?
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 1983 Cross Fire Injection CFI Fuel Line
I just replaced my fuel filter on my 1983 z28 cfi. carquest auto parts ordered a the exact replacement filter. if you do not have a local carquest, try carquest.com.
The shop I work at has this kit,
http://www.qualitytoolsforless.com/P...FVIV7AodZ20AhA
It has saved me time and time again! Very easy to use, and great quality!
Car: 75 Beast
Kit is very expensive for one time use.
From practical consideration 1982-83 Crossfire Camaros uses Wix 33478 {G3694} inline fuel filter. One side is 3/8" hose bead, while the other port is inverse flare. You can always get inverse flare to 3/8" hose barb adapter and runs short piece of 3/8" SAE 30R6 fuel line.
9192camaro
16
02-03-2019 12:21 AM
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
