which wire should I tap into for my 3 wire o2 sensor
Old 05-09-2013, 09:39 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have a 88 gta and was wondering which wire I should tap into for my 3 wire o2 sensor. it has to be a ignition switched 12 v wire
thanks
Old 05-10-2013, 03:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: which wire should I tap into for my 3 wire o2 sensor
The switched side of the OP switch ?
Hot as soon as engine makes 4psi oil pressure and dead when the engine off.
Other popular supply point is the switched side of the fuel pump relay
Old 05-10-2013, 07:58 AM
Guest
Guest
Posts: n/a
Radio power like everyone else....
Old 05-10-2013, 08:54 PM
jamon8's Avatar
Engine: 350 tpi
what are you talking about radio power???
Old 05-10-2013, 09:07 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Bingo!
Old 05-10-2013, 10:02 PM
Guest
Guest
Posts: n/a
lOl
-the power to the radio
Old 05-11-2013, 01:59 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Straight from the "Bubba book of Auto wiring tips"
Why would you use a power supply inside the car that requires running a new wire through the firewall to the O2 sensor
when you already have one available low down on the engine block
Old 05-11-2013, 09:59 AM
jamon8's Avatar
Engine: 350 tpi
which relay is the fuel pump relay and what wire should I tap into
its a 88 gta
thanks
Old 05-11-2013, 10:09 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Use the grey wire on your fp relay it next to the brake booster on the bulk head.
Old 05-11-2013, 11:47 AM
jamon8's Avatar
Engine: 350 tpi
I don't want to get this wrong so could you tell me which relay is the fuel pump relay
here is a pic
Attached Thumbnails which wire should I tap into for my 3 wire o2 sensor-m_002.jpg
Old 05-11-2013, 08:00 PM
Engine: Lb9
Transmission: M20
The relay has 4 wires, black, grey, orange, green with white stripe.
black = ground
orange = battery = 12v+ always
grey = wire out to fuel pump (on some cars this wire is tan with white stripe)
green/white = signal wire from ECM
meeklay812
10-01-2015 03:46 PM
SS-EXPRESS
09-28-2015 09:14 AM
tattmann
09-27-2015 05:20 PM
wstephan96
09-25-2015 04:28 PM
Ironhead38
09-07-2015 02:26 PM
Quick Reply: which wire should I tap into for my 3 wire o2 sensor
