Humming Sound?
Old 12-13-2012, 05:52 PM
19875speed's Avatar
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
Humming Sound?
I have a 1987 firebird 5-speed v6 recently started making a humming noise that seems to get louder the faster I go. Just replaced both axle seals and axle bearings and new back brakes. The noise is still there. The car drives fine with no problems just the humming sound. Anyone have any ideas of what this could be?
Old 12-13-2012, 06:32 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Humming Sound?
wheres it humming from. Front or rear?
Old 12-13-2012, 09:17 PM
19875speed's Avatar
Axle/Gears: 3:45
Re: Humming Sound?
At first I thought is was coming from the rear but its hard to tell, could be the front.
Old 12-13-2012, 10:08 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Humming Sound?
Rear-- Check // change differential gear lube.
Dash area-- Speedo cable may need a bit of lube ( IDK what to use, if that's where its coming from, ** may need** have to remove gauge panel. )
Some one with experience could point you how if its the Speedo cable.
Old 12-13-2012, 10:17 PM
project89's Avatar
Re: Humming Sound?
check the rear diff to be sure its got gear oil in it.
check the transission for fluid as well
can also be a u joint on the drive shaft going bad
does it only make noise when u are pressing or off the clutch peddle, if so it could be the throw out bearing
if its in the front u could have an accesory pully bearing starting to go and or u could have a wheel bearing starting to go bad
Old 12-14-2012, 09:48 AM
19875speed's Avatar
Axle/Gears: 3:45
Re: Humming Sound?
thanks for all the advice! differential fluid was just changed, I was thinking it could be a wheel bearing on the front. if it is a wheel bearing is it safe to drive and how long can it be driven like this? thanks
Old 12-14-2012, 01:17 PM
project89's Avatar
Re: Humming Sound?
if its a wheel bearing it is not safe to drive, eventually the wheel bearing will seize up and lock up the tire or worse it may come off.
if the bearing does seize it usually welds itself to the spindle ruining it. so its alot cheaper to replace it before it fails
iirc the inner/outer wheel bearings set is around 20 bucks
Old 01-04-2013, 01:23 PM
19875speed's Avatar
Axle/Gears: 3:45
Re: Humming Sound?
Turns out it was bad wheel bearings in the front both sides were bad. Thanks everyone for the advice!
Lbibb
05-05-2016 12:00 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
wanext
10-06-2015 12:18 AM
Fanatic1074
10-02-2015 03:47 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Quick Reply: Humming Sound?
