Delrin Bushings
Car: 92 Camaro Convertable/ 68 Camaro SS
Transmission: Auto 700R4
Axle/Gears: 86 TransAM posi rear. 342 gears
Delrin Bushings
Does anybody make Delrin Bushings for our stock A arms ?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Delrin Bushings
Global West is the only company I know making Delrin bushing for the stock A-arms.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Car: 1986 Trans Am
Re: Delrin Bushings
Same here I love them, just wish I had my A-Arms powdercoated when they were out for the bushings.
Re: Delrin Bushings
thanks for the info guys. Im looking more into it. just seems a lot for bushings. But you dont half to sell me on GW stuff. I have their coil over a arms and Cat 5 springs in my 68SS. thanks again
Re: Delrin Bushings
Need drilling for the fittings?
Car: Z/28
Transmission: Turbo 400
Re: Delrin Bushings
yep, I have had Globalwest delalum bushings in my 3rd gen for over 20 years! They still look like and perform like brand new!!! Globalwest rocks!
Car: 1989 GTA
Re: Delrin Bushings
Re: Delrin Bushings
Engine: 4++,350 & 305 CIs
Re: Delrin Bushings
Put a lil motor oil on the poly pivit points. It works better than their sticky binding grease..
Re: Delrin Bushings
Just put it on the parts that touch when they move, poly and metal. It may take some driving and a few times to get it all in there.
Re: Delrin Bushings
Re: Delrin Bushings
Bushings for stock A arms or rear control arms normally don't have grease zerks.
Car: 87' IROC
Re: Delrin Bushings
People like delrin because:
It is self lubricating (no lube, no mess, no maintenance)
It is silent
Articulates very smoothly, no binding
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Re: Delrin Bushings
Any thoughts on the AFCO Light Weight Bushings P/N 20077LW & 20069LW? They have the Delrin core, the only difference is the steel housing (as opposed to the aluminum GW version) and they're less expensive.
Re: Delrin Bushings
Which he stated in a earlier post, that his are a early set without zerks.
Those AFCOs look nice, a lot of friends use them in race cars..
Re: Delrin Bushings
While poking around the Googles, I saw a remark to the effect that the Delrin bushings, while making for "tighter" ride, also make for a harsher ride. Not all of us are driving our Camaro's primarily as racers. Anybody with actual experience have an opinion on whether the Delrin bushings made the ride more harsh? Anybody wish that they had just use the rubber-dampened bushings to maintain a more civil ride?
Re: Delrin Bushings
Certainly the choice of shock absorber will have a greater impact on the ride quality than the Delrin bushings.
Car: 1989 GTA
Re: Delrin Bushings
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: Delrin Bushings
I have the polygraphite bushings on my stock A-arms and not one squeak. Come to think of it...i have full poly on everything and i have no squeaks at all. Rattles are another story
Re: Delrin Bushings
I used the supplied grease when I had them in my car and they squeeked when it was cold out.
After fighting with them for a few years, I completly took them apart, used anti-seize and a bit of motor oil on everything, bam, no squeeks ever again.
Car: Z/28
Re: Delrin Bushings
I have had delrin bushings from global west installed in my front A-arms for 20 years. They are still as good as new. the only way to go
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Delrin Bushings
Worth a shot if you're curious? I don't see why not. I still opted for MOOG standard bushings, though. Played it safe, I guess.
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Re: Delrin Bushings
I just found some polyurethane bushings (brand new still in the packaging) from way back when (around 1995).....do I run 'em or spend the $ on delrin?
Re: Delrin Bushings
I want to grease up bushes every time I change engine oil in order to prevent their early wear out, so grease fittings are a must for me.
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Re: Delrin Bushings
If the answer was obvious, I wouldn't have asked the question....enlighten me!
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Delrin Bushings
Depends... is it worth $140 to you? Because I spent $13 on my MOOG replacements (RockAuto), and I'm more than happy with those. Why spend the money if you already purchased a set of poly bushings that will work? It'd be one thing if it were cheap, but $140 is nowhere near the "cheap" spectrum.
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
Re: Delrin Bushings
Thank you for your 2 pennies and I can agree with you in regards to budget builds, with all due respect, the thread/my question isn't about cost savings. I would like to know if people prefer the delrin over polyurethane or if the end result is pretty much the same? I am willing to spend the $ if there is a difference from a handling perspective. I've never used poly control arms bushings but I have used the GW setup on other cars.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Delrin Bushings
FWIW: I actually don't have a budget build, and I still went with stock replacements because I happen to have poly and/or rod ends on the rest of the car and I'd rather not make the whole car stiff as a board. Haha. That was more my motivation over the cost hike, honestly.
