L88 Hood Scoop Install
Old 10-13-2012, 06:46 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I've decided to change up the look of the Z-28 that has had a 2 1/2" cowl hood on it since 1993 when I had the car painted. I decided to mount an L88 hood scoop onto the original SMC Z-28 hood that came on my car in 1982. I bought the 3 3/4" tall version in fiberglass from Summit Racing and have begun the process of modifying the hood. I have cut the opening after laying out the scoop and getting it dead center on the hood, making sure to leave all the factory hood structure in tact for structural integrity. Once I get the hood bonded with 3-M's 8116 2 part epoxy made for bonding fiberglass to SMC or visa-versa. The next thing I need to do is sand the area around the hood where the scoop will be bonded for proper bonding and then begin the process of getting everything smooth for paint. I will post some pics as I go. I have always liked the look of the L88 hood on the corvettes and it is one of those love it or hate designs. Seems you see a lot of the cowl hoods and I am one who likes to have a little different look. I have the 5" tall rear Hawks spoiler when they first came out with them and have always had compliments on these cars looks really good with the tall spoiler.
Old 10-15-2012, 03:43 PM
COTM Editor
BADNBLK's Avatar
Re: L88 Hood Scoop Install
Post a couple pics. I'm intrested in how this will come out. I have seen more than one of those just riveted on, or bolted and bondoed!
Is your car a SC?
Old 10-15-2012, 03:44 PM
COTM Editor
BADNBLK's Avatar
One of the guys in my club...
Old 10-15-2012, 04:19 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
My car has the t-tops and is an original Z-28. I'm waiting to get my camera back to take some pics of what I have done thus far. I have the opening cut out and everything sanded, a friend of mine is loaning me his gun for the 3-m 2 part epoxy that I am using to bond this onto the hood. When I am done it will look as though it was made as a one piece hood and not a seperate scoop added. I didn't want to spend 400.00-500.00 for the L88 hood when I had the original plastic/glass hood that came on the car.
Old 10-15-2012, 06:54 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
You camaro Guys have it easy when it comes to hood scoops I have the L88, ZL1 hood scoop molded to my trans am hood and wasn't easy to do with the curved hood
Old 10-15-2012, 09:40 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
IMO,Any one that knows anything about cars will see its a Corvette hood scoop added to a Camaro hood and it does scream Corvette a little to loudly.I do beleave in doing what you want with your own car because after all that what its all about. Doing what you think looks best for you. Even though its not something I would do I am very interested in the process/modification your doing.
Old 10-16-2012, 06:56 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
I agree, that's what I like about this hobby called hot rodding. I have things done that reflect my time and age when it comes to hot rods, such as the lettering that I had done years ago with the pinstripping that an artist did for me. As for being a Corvette hood style scoop, that's ok too, I like the look and it will go with the C-5 Corvette calipers that are on the front of the car in bright red and the word "corvette" showing, it's all good and fun. As I said , I will get some pics up shortly to show the progress. The hood is cut out where I needed and it will give me some much needed clearence for my air cleaner. The other mod I am doing this winter is the PBR calipers for the rear as well as a new chrome mastercylinder/booster and lines.
Old 10-17-2012, 05:01 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Here's a couple of pics of the hood cut out for the scoop. I followed the lines of the hood and that is why it has the appearence of no being totally square, I felt looks fine and that way I kept nearly 99% of the bracing for strength. Next is to get it bonded and then working it until there is no seam visible where the scoop and hood are bonded.
Attached Thumbnails L88 Hood Scoop Install-hood-pics-006-medium   L88 Hood Scoop Install-hood-pics-008-medium
Old 10-22-2012, 12:25 PM
Car: 1987 Trans Am
Engine: 355 tpi
It doesn't look like you will be able to take full advantage of that scoop the way you have it cut out, That scoops design has a built in heat extractor built in, And that area will collect rain and dirt if it doesn't have a place to go,
Now if it were me I would strengthen up the hood in the center before I molded the scoop , Other wise the hood may flex and crack at the seems, I would weld some metal around the hole that you cut, then mold in the scoop.
Frozer!!!
01-19-2024 04:55 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
ElPaleterro85
08-13-2015 03:49 PM
bryan623
08-10-2015 11:33 AM
Quick Reply: L88 Hood Scoop Install
