remote solenoid starter for v6.. no suppression diode??
Old 09-11-2012, 12:46 PM
Timothykaleb's Avatar
Okay guys I have a 91 camaro rs which has the hot start problem. I bought the jegs remote solenoid from this link http://www.jegs.com/i/JEGS/555/10301/10002/-1 But if you go down and read the details it says you CANNOT instal this on a computer controlled car? It says it will cause damage, because it has no suppression diodes. Is this
true? Did I waste my 25$ on this? Plead help!
Old 09-11-2012, 12:57 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: remote solenoid starter for v6.. no suppression diode??
How are you trying to use this to fix the hot start ?? where are you planning on putting this in the system
Old 09-11-2012, 09:18 PM
I know that adding a remote solenoid will solve my problem. I just need to know what kind of diodes I should bridge the solenoid with... I got that idea from a different website, it said to jump the two screws on the solenoid with a diode (see http://www.suregripcontrols.com/install_suppress.htm ) but im still confused? Is it talking about jumping the two screws or like the side with positive from the battery, and the other screw on the other side? Can someone just clarify this with me... im not too knowledgeable about this kind of stuff.
Old 09-11-2012, 09:22 PM
Might be called a flyback diode
Old 09-11-2012, 10:06 PM
https://www.thirdgen.org/solenoid im going to use it to fix this EXACT problem.
3rd gen money
10-11-2019 09:57 PM
Gunner242
12-25-2015 04:49 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Jlanz55
09-29-2015 08:55 AM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: remote solenoid starter for v6.. no suppression diode??
