Can engine steam cleaning cause problems?
Old 08-08-2012, 05:08 PM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I've read that it could potentially damage sensors or get water in the brake lines and cause rust or other things like that. Has anyone had this done before?
Old 08-08-2012, 09:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Can engine steam cleaning cause problems?
I personally,wouldn't do it.Nice very damp rag and some cleaning solution,works all the time.
Old 08-08-2012, 09:56 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
It can cause problems by putting water vapor in electrical connections (steam can get places liquid water can't)
Old 08-08-2012, 11:31 PM
SinCityLocal's Avatar
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
I've done it, but only on non-computerized vehicles.
I always did it with the engine running, so I knew what got wet when/if the engine died.
I also tried to avoid spraying directly at the carb, dist, and alt, for obvious reasons.
Too many things to avoid with all the connections on computerized engines!
Old 09-13-2012, 10:09 AM
Engine: 5.0 L03 V8
I dont think I'm going to take the risk then
Old 09-14-2012, 09:15 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I have never done it and I hate water on an engine. My engine needs cleaned bad and a good steam or hose down would do wonders, but i'm not going to do it. I have seen guys soak the engines. When I was a service advisor at a BMW dealer we would tell people that we will not clean the engins as part of a detail due to many cars not starting for days afterwards.
Spyder_TheGamer
12-25-2015 05:07 PM
lakeffect2
08-23-2015 08:44 AM
db057
08-22-2015 08:17 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: Can engine steam cleaning cause problems?
