Opinions on proper valve adjustment hydraulic cam/lifters, with roller rockers
Old 07-25-2012, 09:59 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
I want some opinions on the proper procedure to adjust valves on my SBC.
350, hydraulic cam and lifters. Chromoly push rods and 1.6 roller rockers with locks.
Thanks guys!
Old 07-26-2012, 12:04 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Opinions on proper valve adjustment hydraulic cam/lifters, with roller rockers
Warm-up eng (a warm eng will idle lower and cut down on the oily mess). Shut it off. Pull valve covers off. Start eng. Back off on rocker arm adjustment until you hear it tapping. Slowly tighten until tapping stops. VERY SLOWLY tighten exactly 5/8 of a turn more, lock it down, done. Repeat with next rockers until they're all done.
Or,, you can tighten them all until they just stop tapping, lock them down. Shut off eng, tighten them all 5/8 of a turn more, lock them down, done..
Let eng cool and clean up the mess..
Don't rev eng with the valve covers off, you will have a lot bigger mess!
Old 07-26-2012, 12:12 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
This has to be one of the most re-iterated questions asked, there has to be hundreds of threads on this. There are several methods - engine running as above, or do half - rotate - do other half, or EOIC, etc.
Old 07-26-2012, 12:15 AM
Engine: 357
I know i tried search i just wanted personal opinion with my rocker setup. This is a fresh engine, so the first run im going to have to break it in, I wanted to get them as close to set as i can before i fire it up, guess ill have to manually roll the motor over and adjust them.
Old 07-26-2012, 01:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by silentkillzr
I wanted to get them as close to set as i can before i fire it up, .
So you don't get a choice with a cold engine.
All you can do is tighten them down until the pushrod stops spinning , then add the recommended 1/2 - 3/4 a turn extra
Old 07-26-2012, 01:47 AM
Engine: 357
Alrighty, thanks for the input!
Old 07-26-2012, 12:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't recommend the push rod spinning method as it is easy to go too far into the pre-load.
It is better to jiggle the push rod up & down. Do this as you slowly turn the nut down until the free play is gone.
On an engine that needs all rockers adjusted I do it this way:
Back off all rockers until they all have play.
Adjust all rockers until there is no play. Just go down one side then the other side.
Rotate engine about 90* and check/adjust all rockers until there is no play. Don't back off any rocker adjust.
Rotate engine another 90* and check/adjust all rockers until there is no play.
Do this for two full engine revolutions.
Now add the 1/2 - 5/8 turn to all rockers to add the pre-load and lock them. To lock them run the allen screw down, then rotate the polylock & allen screw together just a hair to fully lock them in place.
RBob.
Mickeyruder
09-02-2015 02:45 PM
SLNTSCPE
08-22-2015 09:15 PM
LT1Formula
08-20-2015 09:36 PM
Dialed_In
08-20-2015 01:45 PM
IrocZ'85
08-17-2015 06:24 PM
Quick Reply: Opinions on proper valve adjustment hydraulic cam/lifters, with roller rockers
