[TX] TBI and TPI to carb conversion kits + other parts
Old 07-13-2012, 08:44 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hello all,
I'm tired of hoarding this stuff, and I need it gone. I've organized all the parts that I have into kits to convert from TBI or TPI to carb. If nobody is interested in the complete kit, I will sell the parts seperately at the prices listed at the end of the post. All of this is top notch stuff that came off of my '87 Formula and '90 GMC Suburban that I converted from TBI to carburetor last year. It was an excellent running combination, but I ended up buying a 454 suburban that was already carbureted, so I don't need this stuff anymore. The pieces, pictures, and parts are listed as follows:
TBI → Carburetor Conversion Kit - $330.00
Virtually everything you need to adapt a TBI car to a carburetor. All that is needed to complete package is the intake manifold of your choice, and gaskets for the intake manifold/carburetor. All else is provided.
1. HEI Distributor
a. JEGS Distributor HEI Distributor (3 years old)
i. Original Paperwork included
b. NAPA Echlin Cap, Rotor, Coil, and Ignition Module (2 years old)
c. Petronix Mechanical Advance Curve Kit
i. Paperwork, instructions, and all extra springs and weights included
d. AC Delco Melonized Distributor gear (2 years old)
i. Non-melonized gear included
2.
Rochester Quadrajet Carburetor
a. Remanufactured Carburetor
i. Chevy Truck, 350 auto, mid-80s, non-Computer controlled
b. Rebuilt in February
c. New Electric Choke (2 years old)
d. Electrical hookup for Electric Choke
e. Jetted for Vortech headed 350 with an LT1 cam
3.
Air Cleaner
a. 14x2” K&N Element (2 years old)
b. Dropped Offset Base for large cap HEI (includes offset stud and wing nut)
c. Chrome “350 High Performance” Lid (1 year old)
d. Will clear Firebird hood with 3” element on stock intake, or 2” element on Weiand Street Warrior/Performer RPM height manifold.
4.
Carburetor Mounting and Linkage
a. Quadrajet Heat Shield
b. Throttle Bracket (w/ TV Cable slot)
c. Throttle Return Springs and mount
d. Includes hardline and fitting for Power Brake Booster Vacuum Line
e. Includes Vacuum port fitting for manifold
5. Mechanical Fuel Pump Setup
a. Airtex Factory Style Mechanical Fuel pump for small block chevy
b. Hard line from fuel pump to carburetor (Rochester carb only)
c. Plate, bolts, and piston to mount mechanical fuel pump in block (must make certain that your block is machined for mechanical fuel pump)
4. It will still be necessary to source fittings and create fuel line to adapt factory fuel lines to the mechanical fuel pump supply and return fittings.
5. It will still be necessary to pull sending unit out of tank, remove electric fuel pump, and braze in a new pickup and strainer sock.
TPI → Carb Conversion Kit - $410.00
Again, virtually everything you need to convert. All that is needed to complete the kit is the intake manifold of your choice, bolts to attach the carburetor to the manifold, and a carbureted TV cable for automatic cars. You will also need a carbureted cruise control if you wish to retain that function.
Includes All Items in TBI → Carburetor Conversion Kit plus:
. Factory Carbureted Manifold Water Neck
2.
3rd Gen Carbureted Throttle Cable
3.
Dayco Carbureted Upper Radiator Hose (2 years old)
Edelbrock Performer Carburetor Substitution - $0.00
1. Can substitute 600 cfm, electric choke, Edelbrock Performer Carburetor in place of Rochester Quadrajet for either package above, free of charge.
2. Will substitute ½” spreadbore to squarebore adapter and bolts necessary to install in lieu of heat shield and gaskets.
Factory HEI Distributor Substitution: -$55.00
1. Can Substitute Factory ’86 HEI Distributor (factory coil, ignition module, cap, and rotor) for a rebate of $55.00 with either package.
2. Non-Melonized Distributor Gear ONLY
Prices for individual components are as follows:
1. JEGS HEI Distributor and associated goodies: $100.00
2. Rebuilt Quadrajet Carburetor: $120.00
3. Edelbrock Performer 600 cfm carb, electric choke, ½” adaptor plate, and bolts: $125
4. Air Cleaner element, base, and lid: $45.00
5. Carburetor Mounting and Linkage: $35.00
6. Mechanical Fuel Pump, mounting gear, and fuel line: $40.00
7. TBI Fuel Pump and Strainer: $30
8. Carb Water Neck and Radiator Hose: $20
9. Carb throttle cable: $25
None of the prices above include shipping costs. Please PM for shipping estimates.
Old 07-13-2012, 09:11 PM
Engine: L98/454/M20
Re: TBI and TPI to carb conversion kits + other parts
More Carburetor Pictures:
Air Cleaner Side View:
Old 07-17-2012, 09:22 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
pictures of the carb mounting and linkages and the throttle cable
Old 07-25-2012, 04:52 PM
Engine: L98/454/M20
There has been some question as to what all is included in the fuel pressure regulator setup. The following chart details the part numbers and original price of all the fittings that are included, already assembled, in this setup. This does not include the price of the regulator, which is $99.50 new.
Thanks,
-cal30sniper
Old 07-26-2012, 04:38 PM
Engine: L98/454/M20
Fuel pressure regulator setup is sold. I can still send with mechanical pump linkage. I also still have the TBI electric fuel pump.
-cal30sniper
MustangBeater20
10-29-2022 09:20 PM
pimp2303
07-27-2017 02:03 PM
86IROC112
08-17-2015 02:00 PM
1nastygta
08-08-2015 07:38 PM
stalkier
08-07-2015 04:49 AM
Quick Reply: [TX] TBI and TPI to carb conversion kits + other parts
