700r4 build, what is a vette servo?
Old 07-01-2012, 05:41 AM
rigsboo's Avatar
ok so i want to build my trans i was thinking of a transgo shift kit most people on here agree but what is a corvette servo? what does it do? and what do i need to make it shift from 3rd to 4th in WOT i seen this (you can either block the Detent passage in your Throttle valve plunger bushing, or just replace the plunger bushing with an
aftermarket one from companies like Superior. The GM Valve kit is P/N 8671953. It replaces the 3-4 shift valvetrain) but i wasnt sure about what to look for in this mess
Old 07-01-2012, 09:03 AM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
Re: 700r4 build, what is a vette servo?
Don't you read? I just explained that yesterday in Rusty Vango's thread.
Old 07-01-2012, 11:19 PM
rigsboo's Avatar
well sir i just looked at the thread and all i gotta say is sorry and thanks you...will the transgo still chirp 1-2?
Old 07-02-2012, 03:08 PM
Pro Built Automatics's Avatar
Blocking the detent passages is by far the cheapest way to go. ($1.25 vs. $40.00 - $60.00) The GM valve kit is for the early 700R4's if I remember correctly. The TransGo Shift kit when setup correctly will give you smooth part throttle shifts and firm WOT shifts. The Corvette servo was designed to improve the 2-3 shift. As horsepower was increasing the 2-3 WOT shift began to exhibit problems, such as a 2-3 shift flare (transmission neutralizing). The 2nd gear servo is the 3rd gear accumulator. Increasing the band release area slows down the band from coming off to fast, thereby forcing more 3rd apply oil to the 3-4 clutches. This will prevent the "shift flare" that was/is somewhat common when using the factory 553 2nd apply servo. This was using the stock six clutch 3-4 setup. Just adding the Corvette servo will also give you a firmer 1-2 & a slightly quicker 2-3 shift. The accumulation needs to be addressed to keep the 1-2 shift from being to firm. The TransGo (Junior & Senior) Shift kit does this. The 700-2-3 Performance Shift kit does not address this. Remember, you want smooth 1-2 part throttle and quick WOT shifts.
Old 07-05-2012, 03:45 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Axle/Gears: Zexel Torsen 3.73, 28-spline mosers
Originally Posted by Pro Built Automatics
Blocking the detent passages is by far the cheapest way to go. ($1.25 vs. $40.00 - $60.00) The GM valve kit is for the early 700R4's if I remember correctly. The TransGo Shift kit when setup correctly will give you smooth part throttle shifts and firm WOT shifts. The Corvette servo was designed to improve the 2-3 shift. As horsepower was increasing the 2-3 WOT shift began to exhibit problems, such as a 2-3 shift flare (transmission neutralizing). The 2nd gear servo is the 3rd gear accumulator. Increasing the band release area slows down the band from coming off to fast, thereby forcing more 3rd apply oil to the 3-4 clutches. This will prevent the "shift flare" that was/is somewhat common when using the factory 553 2nd apply servo. This was using the stock six clutch 3-4 setup. Just adding the Corvette servo will also give you a firmer 1-2 shift. The accumulation needs to be addressed to keep the 1-2 shift from being to firm. The TransGo (Junior & Senior) Shift kit does this. The 700-2-3 Performance Shift kit does not address this. Remember, you want smooth 1-2 part throttle and quick WOT shifts.
I think this "Flare" you described is exactly what my tranny is doing occasionally in another thread I just started. Could you please explain it on that thread? Here's the link to it. Thanks!
Transmission slipping?
RyanJB
Members Firebirds
39
11-20-2018 03:30 PM
plm99
Southern California Area
11-16-2015 05:21 PM
WickedBowtie
Members Camaros
09-17-2015 09:13 AM
WickedBowtie
09-11-2015 11:24 PM
scottmoyer
09-07-2015 07:06 PM
Quick Reply: 700r4 build, what is a vette servo?
