My Vortec headed 383 - Dyno Results!
Old 05-23-2012, 03:12 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I recently built a Vortec headed 383 for my 86 IROC, last saturday we finally got around to putting it on the dyno. The Specs are as follows:
"880" roller block, Scat crank, Compstar rods, wiseco forged pistons, 10.2:1 CR, custom hyd roller cam (.563"/.544", 224/229 duration @ 0.050", 110 LSA, installed on a 108 intake centerline) 906 vortec heads, CHE bronze valve guides installed to solve the retainer to seal clearance issue, valve sizes were opened up to 2.02"/1.60", Bowls were blended to accomodate the new larger valves, spring pockets were cut to fit a beehive valve spring, machined them for screw in studs and guideplates. No other porting was done to the intake ports, the exhaust we raised the roof of the port 0.075" and opened up around the guide. The intake was a edelbrock performer RPM, with AED 750HO carb.
Here are some shots of building/machining the engine...
Boring it the cylinders
Surfacing the block
Torque plate bolted on, preparing to hone the cylinders
Honed!
Weighing parts for the balance
Scat crank
Balancing the crank
Checking pin bore clearances.
Old 05-23-2012, 03:17 PM
Car: 1979 Malibu
Engine: Blown LSx
Re: My Vortec headed 383 - Dyno Results!
Block all washed up
Block painted w/ cam bearings and plugs installed.
Checking bearing clearances
Crank and cam in.
Degreeing the cam, I advanced it 2 degrees.
Checking my rod bearing clearance
Gapping piston rings
Assembling the rods and pistons
Old 05-23-2012, 03:21 PM
Car: 1979 Malibu
Engine: Blown LSx
All together and in the engine...
Shortblock almost done.
Checking rotating clearance on the pan, had to notch it for the lokar dipstick. Thats it.
Bolted up
Porting the exhaust ports
Valve job and blending done to the bowls
Crower Enduro stainless bodied 1.6 ratio 7/16" stud rockers
Isky adjustable guideplate to get the rocker tips to sit properly
Old 05-23-2012, 03:26 PM
Car: 1979 Malibu
Engine: Blown LSx
I was originally goign to run a Comp dual spring, witha crower titanium retainer but I wanted to lighten up the valve train so I switched to a beehive witha steel retainer. Big weight savings
Porting all finished up
cc'ing the chambers
Spring pockets machined to fit a ID style of locator
A bunch of material ground out of the pushrod area
Surfacing the heads
Porting the intake
Heads surfaced
Old 05-23-2012, 03:35 PM
Car: 1979 Malibu
Engine: Blown LSx
Stud bosses milled .400"
Lapped the valves
Figured out my pushrod lengths
Did a mock assembly to check PTV etc... had .140"+ PTV on both the intake and exhaust, brow clearance was good aswell.
Heads fully assembled
Bolted on
Guideplates fit and studs torqued down where I want them
Manton 5/16" .118" wall 7.300" pushrods
Old 05-23-2012, 03:39 PM
Car: 1979 Malibu
Engine: Blown LSx
Rockers installed
We lube the pushrod and valve tips with this
Filled with Joe gibbs breakin oil
Checking port alignment
Intake bolted up and sealed, primed it, had 60psi oil pressure, had oil to all 16 rocker in under 20 seconds.
Pretty much ready for the dyno.
Old 05-23-2012, 03:53 PM
Car: 1979 Malibu
Engine: Blown LSx
Bolted it up to the dyno friday night, my hooker supercomp headers wouldnt fit so I bolted up a set of out 1 3/4" dyno headers.
Started the jetting out at 72's in all 4 corners with 4.5" power valves, First pull it made 451HP, and 472 ft-lbs of tq.
Took two jet sizes out of it and made another pull, 455 HP and 475 ft-lb's of tq.
BSFC was telling us the fuel curve was where is need to be, So I gave it another 2 degrees advance (34-36) which picked up the HP a bit
We figured it wanted more plenum volume so we tried a 1" open carb spacer which woke it up alot. W/ 36 degrees total timing, 70's all around it made 466hp, and 486 ft lb's of tq.
We had a bit to much oil pressure, so we drained the breakin oil, cut open the oil filter, which was clean, and filled it up with Joe Gibbs 10w30 synthetic hot rod oil. We also blended the 90 degree edge where the choke horn was milled off and jetted the primaries up 1 size to a 71. Opened up the high speed air bleeds 0.005" as it was a little fat in the top end. This pull brought us to out final numbers 474HP @ 5500RPM, and 493 ft-lbs of tq @ 4800RPM. It made over 420 ft lbs of tq at 3000 RPM and carried it to 6000RPM. Overall I am very happy with the results considering its a GM head casting with dual plane intake.
Here is a video of the second to last pull
http://www.youtube.com/watch?v=ni0xCy9bmTM
Old 05-23-2012, 04:02 PM
conlinj's Avatar
Nice results, can't wait to see some ET's out of it. Also it gives me some ideas for my old vortecs that are sitting around. Hopefully my AFR vortecs make as much power as yours did.
-Jim
Old 05-23-2012, 04:07 PM
Cosmik Debris's Avatar
You don't have any more pictures do you? :-) Nice job.
Old 05-23-2012, 04:33 PM
Car: 1979 Malibu
Engine: Blown LSx
Yah, look at my build thread haha.
Old 05-25-2012, 03:27 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
I just found this thread, sounds like you did something very similar to what I had in mind. Guess I won't be worrying about the power LOL! I was hoping for 425 or so. But it seems like I'll getting what I want and then some. Where is your build thread so I'm not digging through all the threads looking for yours.
Old 05-25-2012, 08:51 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Once you get it installed, it sure would be interesting to see a chassis dyno result! I always see engine dyno numbers, or chassis dyno numbers, but rarely both.
I enjoyed the pics, real nice build and that's gonna be one torque monster engine. Good luck with traction on the street.
Old 05-25-2012, 10:14 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
Good results.
Old 05-28-2012, 10:44 AM
Car: 1979 Malibu
Engine: Blown LSx
There is a link to it in my sig.
MustangBeater20
10-29-2022 09:20 PM
84z96L31vortec
08-20-2017 12:16 AM
Tinbender59
03-17-2017 10:50 AM
bamaboy0323
09-03-2015 06:07 AM
earlpote
08-28-2015 10:42 AM
Quick Reply: My Vortec headed 383 - Dyno Results!
