lg4 to orange block 350 with 325hp
Old 05-17-2012, 07:43 PM
Slowpoint0's Avatar
Car: 1986 t/a
Engine: Lg4 305 carb
Transmission: 700r4 auto
Axle/Gears: 2.73 posi
CHEVY 350-325HP ENGINE MIDNIGHT HOT SALE ORANGE CRATE ENGINE HIGH PERFORMANCE.
in couple months i want to put 350 in my lg4 (slowpoint0) i can get this engine for $1500 all new parts NOT a Reman..
would my 700r4 hold this engine with a 2200-2500 stall converter
Old 05-17-2012, 09:55 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: lg4 to orange block 350 with 325hp
If that is supposed to be a link it isn't. Even with out seeing a link, I can tell you your transmission will hold up just fine assuming it is in good running order.
Old 05-17-2012, 10:03 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
How does a company sell a NEW 325HP 350 for $1,500?
If it's an ebay motor, run the other way. I looked at a third gen with a "400 horse ebay motor". He had the reciepts totaling 2 grand, it was clearly the same motor. It was also nowhere near 400 horses when I laid into it.
Old 05-17-2012, 10:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It is called a rebuilt engine,
If it's an ebay motor, run the other way. into it.
This one maybe ?
http://www.ebay.com/itm/CHEVY-350-32...item2ebe5959a4
"This Engine has The First Generation Swirl Vortec Heads "; just to confuse a unknowing buyer into thinking they have real Vortec heads ; not earlier swirl ports
Always worries me when a seller takes 4 pages and lotta colors to describe how good his engines are
The only time they mention a brand name of a product used it is a a lower end one ( Speed Pro ) so what part of China do the rest come from
Old 05-17-2012, 10:18 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
It worries me when the list of parts is vague. It worries me even more when their is no mention of any of the parts that actually determine it's power output.
It's probably possible to squeeze 325 horses out of a high compression small cam Vortec motor but I'd be skeptical.
Old 05-17-2012, 10:47 PM
85T/A350's Avatar
Engine: 350 Vortec
Even if they did get 325hp I'm sure it was on an engine dyno, using dyno headers, turning no accessories, etc.
Old 05-17-2012, 11:00 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
We have all seen this game played a million times and there are a nearly endless number of either frustrated, disappointed engine swappers or blissfully ignorant ones who are confused about why 90s minivans can outrun them.
Do yourself a big favor and read through this thread:
https://www.thirdgen.org/forums/tran...tion-side.html
There are many like it, but this is just the most recent example.
If you want to believe some ebay dude's marketting hype and vagueries and think you're actually getting a 325 hp 350 for $1500, then by all means go ahead and spend all your money and work on it.
To get 300hp out of a 350 requires a lot of attention to detail, and good, well-matched parts. It's not hard, but you have to know what you're doing.
Old 05-17-2012, 11:38 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
325 HP with swirl-ports takes an awfully huge cam. In this scenario, the cam starts working just when the heads are all done. Worst compromise possible. No low-end TQ, no top-end HP, and no driveability. THE ONLY all-new 350 for $1500 is GM's own Goodwrench, and it's nowhere near 325 HP. Sometimes you see claims around 250 HP, and that's possible if you don't figure the p/s pump, a/c compressor, et cetera. But if you want an all-new 350 with a warranty, it ain't a bad way to go. Be aware it isn't really 8.5:1. It's actually 8.0:1 w/ GM steel-shims, or 7.8:1 with GM 0.028" composites. Comp's PureEnergy makes for a perfect upgrade cam for it. Then you can hope for around 265-275 HP with headers and a decent intake. If you want 325 driveable HP, it's going to cost more. If you want a warranty, it'll cost a lot more.
Old 05-18-2012, 11:58 AM
Slowpoint0's Avatar
Car: 1986 t/a
Oh maybe they are on eBay I just googled 350 engine and it gave me a list of sites.
It wasn't eBay or Craigslist but the link (Vetteoz) posted does sound just like it!! No pretty colors or 4 page write up , but yes ebays seems to be same parts.
Thanks guys
Old 05-18-2012, 12:34 PM
Slowpoint0's Avatar
Car: 1986 t/a
im gunna save for a REAL engine jegs ZZ4 turnkey for $5,300
Old 05-18-2012, 01:01 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Obviously everybody else who responded is right but I am still trying to get past the gimmick Midnight Hot Sale Orange part or the description. I am definately not the most knowledgable but none of that means anything to me and doesn't even sound like a good gimmick catch phrase. I might let the Orange go though.
Old 05-18-2012, 01:12 PM
Slowpoint0's Avatar
Car: 1986 t/a
its what they call there engines. they name them by color of the block
Old 05-18-2012, 03:05 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I can't clearly ID those heads as vortecs because the picture is too small, they are obviously center bolts. They claim they are Vortec heads but many people call the earlier TBI swirl port heads "Vortec" heads.
If it's a swirl port set of heads, no way in hell in any scenario they are making 325 hp.
I'm about done assembling a true 325 HP motor , reusing the rotating assembly (polished crank, new bearings, rings, etc) I'm in it for about $2,200. I had the long block (vortec heads) laying around. Only labor I paid for was $800 in machining on the heads, valve job, mag/polish crank, install new springs/retainers/locks/seals/guides. About 9.2:1 compression; took a 224/230 duration .502"/.510" cam to get there.
Old 05-18-2012, 03:27 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
"This Engine has The First Generation Swirl Vortec Heads"
AKA shitty heads
Old 05-18-2012, 04:45 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
AKA shitty heads
325 horses without accessories on an engine dyno? Maybe with a 100 shot haha
Old 05-18-2012, 05:01 PM
Slowpoint0's Avatar
Car: 1986 t/a
would lg4 parts fit 350 block?? if i started with say the goodwrench motor or something like it? intake, carb, accesories ect?
Old 05-18-2012, 05:24 PM
Slowpoint0's Avatar
Car: 1986 t/a
my goal is to just have something fun to drive around in, not looking to do 10s on the street! but would like to break 13s when i want to mash my foot to the floor. real 250-300hp from the rear wheels would be nice.
it is and will remain an everyday driver, emissions not a prob, but decent fuel mileage would be nice when driving like NANA.
i want go,mileage, and highway manners. dont want to cruise at 60 at 4000rpms
Old 05-18-2012, 07:28 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
You have a ton of options for a 12-13 second car that can break its tires lose on demand... can it be done for less than $1,800? Maybe... but not reliably. I am telling you though, that motor you are looking at won't blow 13's even.
Your options are unlimited. If I was you I'd find a cheap high mileage Vortec 350 that's in descent shape. From my experience they are usually in awesome condition as long as they weren't starved of oil. I had one with 275,000 miles that still showed cylinder cross hatching, reusable lifters, crank measured perfect although I had it polished while it was out, new rings and all new bearings. My labor to have the block cleaned, inspected, crank magnafluxed/polished, new cam bearings and new freeze plugs was like $300. I had to purchase all the bearings (which shouldn't be more than $100).
For the heads you'd want to have them cleaned up, valve job and rebuilt with new springs/retainers/locks/seals/screw in studs. I spent about $350 on parts and the machine shop did everything from disassembly to reassembly for about $500. My factory pressed in studs were very secure and probably didn't need to be changed for what I was building. Could have saved $150 off the total price (parts and labor) if I didn't change them. So for around $850 you have an awesome set of heads. (You can also buy them from Scoggin Dickey for that price).
Total price is around $1,250 at that point. Factor in another $300 for the cam, $50-150 for rings, $50 for the oil pump, and about $200 in gaskets, push rods and water pump. You would be right around the 2 grand mark and still need rockers (vary depending on what studs you use $150-250), timing chain, vortec specific intake manifold and a carb. You'd be around the $2,600 mark not counting what you paid for the motor.
Easily can make a reliable 350+hp/400 ft lbs out of a daily driver Vortec 350 for about $3,000. Can get you into the 12's relatively easily if your car is set up right and would make a very fun street car with all that torque!
Old 05-18-2012, 10:06 PM
Slowpoint0's Avatar
Car: 1986 t/a
votech 350? does it matter year? i like the carb set up rather then fuel injection..
what would i need to put this in my car? my 700r4 was rebuilt about a month ago i have a transgo shift kit not installed but i herd its better then the b&m.
i can get a vortech from a wrecked camaro few streets over from me. for about $1000 it has 80k on it and runs great back of his car wrecked front end and motor untouched
Old 05-18-2012, 10:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If I was you I'd find a cheap high mileage Vortec 350 . You'd be around the $2,600 mark not counting what you paid for the motor.
Another option .FREE Shipping
http://www.jegs.com/p/GM-Performance...13788/10002/-1
States at top
http://www.ebay.com/itm/ws/eBayISAPI...m=200762831123
Old 05-18-2012, 10:14 PM
Car: 1992 Camaro RS
There's no H in Vortec. It ONLY applies to 96-98 trucks. I think there were a few in 99 and 00 that might ahve still gotten those heads, but you're looking for an engine from a 96 to 98 truck that has 906 or 062 casting heads.
Do a stock rebuild, upgrade to LS2/LS3/LS6 style GMPP "yellow" beehive springs, Comp beehive retainers, run 1.5 rockers, and an LT4 hotcam and you'll be in the 330-360hp range for pretty reasonable money.
And to be completely clear, I think these ebay engines are probably reliable and well-built, but they're just not performance engines. Its not hard to build a reliable engine at the power levels these engines are probably at, and with that in mind they're really not that bad for the money, but that engine that vetteoz linked to, with its factory roller cam, is still going to be a better buy and a better deal. Just swapping in something like an LT4 hotcam (some minor tweaks needed to make sure that works out due to lift limitations of those heads) will make it a total beast as long as you can fuel and exhaust it adequately.
The other concern is that these factory rebuild type engines dont use ARP rod bolts. In and of itself it's not a huge deal, just a little high RPM insurance for down the road if you ever want to spin it to 6000+ RPMs.
Old 05-18-2012, 10:41 PM
Myslowbird's Avatar
Car: 1986 trans am
Engine: 305 lg4
Transmission: 700r4 automatic
[QUOTE=InfernalVortex;5277598]There's no H in Vortec. It ONLY applies to 96-98 trucks. I think there were a few in 99 and 00 that might ahve still gotten those heads, but you're looking for an engine from a 96 to 98 truck that has 906 or 062 casting heads.
and (ahve) is not a word!! damn typos..haha
the engine Vetteoz posted is what i was asking about?? would anything from the lg4 transfer over to it? or lg4 stuff just a waste??
Old 05-18-2012, 10:46 PM
Myslowbird's Avatar
Car: 1986 trans am
Engine: 305 lg4
whoa thats what i was going to ask
Old 05-18-2012, 10:51 PM
Slowpoint0's Avatar
Car: 1986 t/a
@myslowbird i read your posts how did your edlebrock kit drive??? what do you want another engine for? did you blow your lg4 up??
Old 05-18-2012, 10:56 PM
Slowpoint0's Avatar
Car: 1986 t/a
what about these kits what do they produce for power??
http://www.jegs.com/i/GM+Performance...353K5/10002/-1
Old 05-18-2012, 11:40 PM
85T/A350's Avatar
Engine: 350 Vortec
I'd say that package would be good for 230fwhp or so with headers and good exhaust. That package would be a very very mild combo. Perfect for someone who wants a nice daily driven package. As far as performance, the intake of choice is the Edelbrock Performer RPM. I have that carb and I like it. Most prefer Holley though. As you should if your intentions are most power and tune ability.
Old 05-19-2012, 12:28 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Originally Posted by vetteoz
States at top
Didn't see it said swirl. Quickly glimpsed over it. I figured for the price they were probably swirl ports but with the vague cam information the only shot it had of making anywhere near 300+ hp was with a real set of vortec heads.
If you're going to pay a shop to do all the motor work for you than just buy an assembled crate motor. It will be cheaper in the long run... and some crate motors have pretty good warranties on them.
Old 05-19-2012, 06:39 AM
Slowpoint0's Avatar
Car: 1986 t/a
other then the popular ZZ4. whats a good turnkey engine? $3500-4500
Old 05-19-2012, 06:48 AM
Slowpoint0's Avatar
Car: 1986 t/a
http://www.jegs.com/i/GM+Performance...10008/10002/-1
think im going to go with this!!! needs water pump. its power i want, in my price range, im going to do 2 1/2 exhaust all the way back, a 2500 stall, and 373 in the rear
Old 05-19-2012, 08:38 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
[quote=Myslowbird;5277622]
Actually, the '99-'01 Vortec 350 full-size half-ton van engines were slightly better machined, and if you aren't buying new aftermarket valves, these flow slightly better on the exhaust side, where the Vortecs need all the help they can get. 1-ton engines had more emphasis on durability than power, so any year Vortec heads can have the worst-flowing exhaust seat angles, and need 1.6" valves to fix. But they're still the same casting numbers. You must pull the valves to see what you really found.
Old 05-19-2012, 08:41 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You're 50 horses short. Something's very wrong. And getting a 9:1 swirl-port 350 to 325 HP with no power adder isn't that hard. It just takes a huge cam, a decent intake manifold, and headers. The catch is that you'd hate trying to drive it.
Old 05-19-2012, 10:39 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Blue Print makes some pretty descent stuff. These are fully assembled and can be dropped in the day it arrives for $3,800-4,200. They are also backed by a 30 month 50,000 mile warranty if I recall correctly.
Dressed 383 -405/440
http://www.summitracing.com/parts/MLL-BP3830CTC/
Another one w/ vortec heads
http://www.summitracing.com/parts/MLL-BP3830CTC1S/
Old 05-19-2012, 01:39 PM
Slowpoint0's Avatar
Car: 1986 t/a
I would need carb, wire harness, computer, flex plate right?
Old 05-19-2012, 05:35 PM
Slowpoint0's Avatar
Car: 1986 t/a
what flexplate would i need with a 383?? i have an auto 700r4 trans..
also how would a 383 be for a everyday driver?? that seems a lot of engine for everyday use, no?
Old 05-19-2012, 05:46 PM
Slowpoint0's Avatar
Car: 1986 t/a
http://www.summitracing.com/parts/NAL-19210008/
this is what im looking for, flexplate,carb,waterpump come with..
i would need the fuel set up, pump,adapter, fuel pump push rod..
what do you guys think??
Old 05-19-2012, 06:36 PM
midias's Avatar
Good engine go for it but check jegs to see if they have the same they often have free shipping.
Old 05-19-2012, 07:00 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If it is a late model block you can't fit a mech fuel pump ( without drilling holes )
Easier to use a elec pump
Old 05-19-2012, 07:07 PM
Slowpoint0's Avatar
Car: 1986 t/a
wouldn't electric be better anyways? and do you do about not having the push rod
Old 05-19-2012, 07:18 PM
Slowpoint0's Avatar
Car: 1986 t/a
think im going with this one! what exactly do i need to put this in and have it run?
is the flexplate that comes with going to work?
Old 05-19-2012, 07:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Should be same 153 tooth flexplate you have now
The pump rod makes the mech fuel pump work off the cam.No fuel pump ; no need for pushrod.
Old 05-19-2012, 07:34 PM
Myslowbird's Avatar
Car: 1986 trans am
Engine: 305 lg4
No, it drives awesome. Just a top end kit, cam, intake, carb, timing gear set, and new fuel pump to feed it.
Hasn't been dynoed yet but,
Messing with a friend in a dyno tuned 345hp stroker Mustang, stock I watched stangs tail from start to finish. Now with my motor done he'll never see my headlights again. Haha.
Not true buddy, (I still have to pull up to your house)
Old 05-19-2012, 07:38 PM
Slowpoint0's Avatar
Car: 1986 t/a
makes sence vette, so straight out the box no other performance additions added what is best fuel pump for this engine?
Old 05-19-2012, 08:22 PM
Slowpoint0's Avatar
Car: 1986 t/a
http://i1242.photobucket.com/albums/...th_transam.jpg
my car pic dont know how to just make it show
Old 05-19-2012, 09:56 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I don't consider a motor that is engine dynoed with no accessories and dyno headers as a true XX hp motor. The way it sits in a vehicle with full exhaust is how I estimate my power numbers. I could lie and give you guys a comparison to a crate motor and guess around 375/440.
Fully dressed I doubt it would break 350 horses and I'm usually conservative on output.
Old 05-20-2012, 07:07 AM
Slowpoint0's Avatar
Car: 1986 t/a
My pic comes up so small!!
Old 05-20-2012, 03:48 PM
Car: 1992 Camaro RS
Youre better off with that engine vetteoz posted. It has a roller cam. That's a big advantage.
http://www.jegs.com/i/GM-Performance...oductId=813788
You can piece together a whole carb setup for probably $500 if you look hard enough. Re-use everything else you have already and you're good to go.
If you put some beehive spring in it you can spend another $300 or so and put a roller hotcam in it (spend another 250 and get an XR276+better springs and it's 375hp) and hit 325-350hp.
That's still significantly less than the engine you posted, which doesnt even have a roller cam.
Old 05-20-2012, 04:16 PM
Slowpoint0's Avatar
Car: 1986 t/a
ok so my flexplate switch over?? and what about the fuel pump for this?
would i reuse lg4s intake and all acc?
Old 05-20-2012, 04:24 PM
Slowpoint0's Avatar
Car: 1986 t/a
would the hot cam be good for off idle power? i want 0-5500rpm power.
Old 05-20-2012, 04:54 PM
Slowpoint0's Avatar
Car: 1986 t/a
to many choices.. for engine in your posts what would be best distrib, whould long tube headers be better? what if i went with top end kit (carb,cam,lifters,rockers,intake,heads)
in all honesty id like to purchase a turn key engine, take away all the guess work out..
something more of a (drop in) deal
Old 05-20-2012, 05:41 PM
Car: 1992 Camaro RS
If you reallly just want to drop something in, go ahead and go with the $3999 motor. It'll have a warranty so it makes it easier for you. No risk of valvetrain mistakes in setup. You may still need to change out the water pump though, depends.
Quick Reply: lg4 to orange block 350 with 325hp
