Cracked Power Steering Pulley What would cause this ( Pics Inside)?
Old 05-09-2012, 08:21 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Noticed my power steering Pulley was cracked. What would cause this the pulley is about 7 years old. Is it dangerous to run it like this?
No wobble in the pulley. Just want to know what might cause this so I can fix the problem and not have to keep replacing pulleys.
Attached Thumbnails Cracked Power Steering Pulley What would cause this ( Pics Inside)?-img_3127.jpg
Old 05-10-2012, 05:19 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cracked Power Steering Pulley What would cause this ( Pics Inside)?
It's made like that.
Old 05-10-2012, 07:31 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
As said above,it's made that way-the rim of the pulley
is rolled into shape from a flat piece and that seam is
welded(actually brazed IIRC).
Old 05-13-2012, 09:07 AM
THETANK's Avatar
Car: 91 rs
Glad to hear that, I never noticed that before. Thanks
Old 05-13-2012, 09:30 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
i noticed the quality of GM pulleys is not real consistant
-common to find ones with axial or radial runout of the
belt grooves-on multi groove pulleys,sometimes only
one groove will be affected.When i noticed this,i went to
my local junkyard and bought a bunch of pulleys-
checked them until i found a set that turned true; an'83
wagon provided a perfect crank pulley,an '82 pickup a
true-turning waterpump pulleyThis phenomenon
exists with GM pulleys well into the '90s at least-have
noticed some pretty bad ones from that era.
BTW,same thing with the heater/AC blower squirrel
cage -those ranged from horrid to perfect,my original
was pretty bad-found a perfect one in an '83 cadi,my
blower no longer "throbs"at high speed like the
wobbling original did
Old 05-13-2012, 12:10 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
lol that had me thinking... I checked mine and yes its made like that..
Old 05-09-2022, 08:55 PM
Xmantwo's Avatar
Car: Jeep
Engine: 3.7 L
Old 05-09-2022, 08:56 PM
Xmantwo's Avatar
Car: Jeep
Engine: 3.7 L
Does power steering pully supposed to have crack?
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
evilstuie
01-09-2020 08:29 PM
colton_carlson
03-08-2019 12:21 PM
Street Lethal
08-12-2015 11:33 AM
Quick Reply: Cracked Power Steering Pulley What would cause this ( Pics Inside)?
