any wiring diagrams for 89 rs camaro
Old 05-05-2012, 10:56 PM
ray1989's Avatar
Engine: 350 40 over
I need some help I am trying to remove all wire that i do not need that wont impede daily drivability. My engine is carbed and therefore does not use the computer in the dash. any ideas on which wire i can remove? I might just take out the cluster and make my own, so then id have to find the wires that control the fuel gauge and connect it to an after market one. I currently have aftermarket oil, temp and tach gauges.
ps i have the dash completely out
any diagrams on what each wire does would be a great help.
Ryan
Old 05-06-2012, 07:50 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: any wiring diagrams for 89 rs camaro
Your best bet IMO would be to head to your local parts store and buy a manual. I am sure someone on this forum will help you but it is very helpful to have the wiring diagram in front of you.
Old 05-12-2012, 04:06 PM
utilityguy2's Avatar
Autozone.com has wiring diagrams for free.
Old 05-12-2012, 04:47 PM
Edwardgp's Avatar
Engine: 454-350
OK Ray there you go, keep us updated.
Old 05-12-2012, 07:05 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Austinthirdgen.org that what I used when I removed the pass harness and wiring
Old 05-12-2012, 07:23 PM
Jeffs82TA's Avatar
libraries sometimes even have them
Old 05-15-2012, 10:15 PM
ray1989's Avatar
Engine: 350 40 over
i removed all that i could can everything still works except i lost my dash lights haha but atleast the wiring harness is alot smaller and no computer anymore
plan to fix it eventually now working on fitting c6 18s and 19s on it now
Old 10-04-2013, 11:52 AM
Biggd4355's Avatar
I need the wiring for the heater fan control switch in my 89 camaro. Neither library, autozone, anywhere has this part of the wiring. I need to know where the brown wire with the white stripe goes. I know it should be switched.
Old 10-04-2013, 02:42 PM
Vette-Tek's Avatar
Autozone.com 1989 body wiring clearly shows the diagram. It does not show a brown/white wire but does show brown wire to fan switch and brown wire from fuse panel.All third gen appear to be the same.
rocn7roc
09-21-2021 02:16 PM
89GTAOz
05-16-2020 09:31 AM
TheJoeY88
12-31-2016 07:30 PM
Caspar
06-19-2016 11:19 PM
Zachattack0925
08-12-2015 09:52 PM
Quick Reply: any wiring diagrams for 89 rs camaro
