finally ready
Old 05-05-2012, 09:29 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
finally ready
i have a big quest. I am going from 89rs with 305tbi to 350vortec carb. and 700r4 and I have a TON of wires that I don't think that I am going to need. So how do i get rid of the excess wires? I know that can run all the wires for my gauges independant and as long as they have power they will work but
my wife for some sick reason wants to try to keep the AC so I cant just cut all of the wires in one swoop. plus I want to try to keep the tbi fuel pump if I could and add a fp regulator that way I ddont have to drop the tank. and not to mention the fp is NEW and so is the exhaust with the 2.5 in chrome tips. Although I guess it dont matter b/c i'm not going back with stock exhaust anyway I bought headers and trying to go with 3in y-pipe and tubing and no CAT all the way to the muffler and want a 3in inlet dual 3in outlet muffler. keep in mind that emissions on 95 and older ddoesnt mean anything in 27524 NC.
Attached Thumbnails finally ready-5.jpg   finally ready-6.jpg   finally ready-4.jpg
Old 05-05-2012, 09:41 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: finally ready
10-4 bro the little advice I can give will pale compared to what others will help you with. I think I would start by getting a wiring diagram.
Old 05-05-2012, 10:14 AM
Car: 91RS
Re: finally ready
kool!
Old 05-05-2012, 05:01 PM
Edwardgp's Avatar
Engine: 454-350
Re: finally ready
Keep us updated, once you get a wiring diagram if you have not worked with one before study it for awhile and it should become clear as to what is what.
Old 05-05-2012, 06:57 PM
danielsan's Avatar
Car: 1984 15th Anniversary Trans Am
Engine: 5.7 Goodwrench (for now)
Re: finally ready
I'm in the process of tucking some wires in my engine bay right now. So far I've found it easiest to cut them back towards the firewall, cap off any hot wires and then use some electrical tape/small zipties to keep it together and somewhat neat. I've been hiding the bundles near the firewall in plastic wire protector that i'm running along the backside. So they're only near the firewall, just in case I ever need them again.
I should mention however that I got the car with a 350 sbc and a/c deleted for the most part.. and the wires i'm tucking away now were disconnected when i got her.
Old 05-05-2012, 11:27 PM
Car: 91RS
Re: finally ready
kool if you dont mindd would you post some pics of your work so I can have an idea of what i can do.
Old 05-08-2012, 05:37 AM
Car: 91RS
Re: finally ready
bump
Rocket-Doc
11-14-2015 02:08 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
meeklay812
10-01-2015 03:46 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
Quick Reply: finally ready
