injector install
Old 04-30-2012, 08:18 PM
87Formula383TPI's Avatar
Car: 1987 Pontiac Firebird Formula 350
Engine: 383 Stroker Tuned Port
Transmission: 700R4 B&M shift Kit, B&M Holeshot
Axle/Gears: Stock 9 Bolt
injector install
Hey I was just wondering if anyone has any tricks for installing the injector clips on the TPI fuel rails. They are a serious pain. Thanks for the help.
Old 04-30-2012, 08:24 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: injector install
They come out easy. You just have rotate the clips.
erik69&85's Avatar
buy Bosch III injectors which don't use clips!...
lol
Old 04-30-2012, 08:28 PM
Hahaha I just got my new injectors so buying the Bosch IIIs wont work for me.
Old 04-30-2012, 08:29 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
erik69 is in Rochester too. Take your fuel rail over there and he'll show you how to take them out without bending up the clips.
Old 04-30-2012, 08:32 PM
Ive got them out its putting them back in that is fighting me
Old 04-30-2012, 08:36 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Lube the "O" ring a bit with something oily. Push the injector in to compress the "O" ring a bit. You might have to wiggle the injector a bit in order to get the reteining clip to start in the slot properly.
Old 04-30-2012, 08:40 PM
Thanks I knew they werent going to be easy so I thought I would get some ideas.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
Firechicken86
08-12-2015 10:07 PM
Quick Reply: injector install
