engine to firewall ground strap
Old 04-24-2012, 10:11 PM
PETERK's Avatar
Car: 2001 F150 SCREW; 92 Camaro RS
Engine: garage built 355
Axle/Gears: possi from Z28
I've looked around and can't find anything. I am wondering what the importance of the engine to firewall ground strap is and besides ground what is its purpose. The reason I ask is I am having a problem with my charging guage jumping around and the although is charging at a little over 14v. I never put this ground on and want to drive the car to work for inspection in am.
Old 04-24-2012, 10:13 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: engine to firewall ground strap
It's very important, it provides ground to the body.
Old 04-24-2012, 10:23 PM
PETERK's Avatar
So what happens if its no there? And what am I risking driving the car if its not?
Old 04-24-2012, 10:42 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Car will likely still run because there are alternate paths that connect the body to the engine. Can't tell exactly what will and will not work with a shaky ground. But it's much better to give electricity the easy path through the ground strap.
Old 04-25-2012, 07:54 AM
PETERK's Avatar
Thanks for the info.
Old 04-25-2012, 04:00 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I made a few of them from some welding wire and the turned out great and look so much better then the stock flat wire junk
Frozer!!!
01-19-2024 04:55 PM
Jae992
08-27-2015 09:07 AM
86IROC112
08-17-2015 07:57 PM
bradleydeanuhl
08-12-2015 11:48 AM
MustangEater82
Brakes
08-11-2015 07:52 AM
Quick Reply: engine to firewall ground strap
