Radio not working
Old 04-11-2012, 09:36 AM
KARR44's Avatar
Car: 89 firebird
Engine: 5.7 l
Radio not working
After market head unit (eclipse)in my 89 formula not working at all checked radio fuse fuse is fine anybody have any suggestions
Old 04-11-2012, 05:48 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
Re: Radio not working
Take the radio out, there should be a fuse on the back of the headunit. If that one is fine then check the radio fuse under the dash, as well as the accessory fuse, and there should be a fuse labeled ARC on the fuse block, make sure that fuse is good. I had an issue with my stock stereo not getting a constant and it ended up being the ARC fuse under the dash. If you did not install the stereo there is no telling what wacky wiring was done, so if fuses don't yield an answer make sure all the wires are still connected and insulated.
Old 04-12-2012, 07:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Some of the harnesses have an inline fuse between the headunit and the stock connectors. Not all Eclipse HUs have a fuse by the connector. Either way, pull the HU out and make sure there is power on the red and yellow lines.
Vintageracer
01-10-2020 05:33 PM
OLDYELLR
Car Audio
09-30-2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
08-15-2015 12:12 PM
Keiffer76
Car Audio
08-09-2015 11:37 PM
Quick Reply: Radio not working
