DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
350 tpi-JET Chip with 305 tpi prom?
Old 02-29-2012, 03:14 PM
irockid43's Avatar
Car: 86 IROC-Z
I am getting ready to fire up my 86 IROC Z. The car had a carb on it, I just put the tpi unit back on. The tpi was from a 305, now I have a 350 in it. I have the ECM and Prom from the 305. I purchased a jet chip made for a 350tpi. It goes between the stock prom and the ECM. Will this work with my 305 Prom?? I have 22lb injectors and a knock sensor for a 350 also.
Any help would be appreciated. Thanks!
Old 02-29-2012, 09:17 PM
utilityguy2's Avatar
Re: 350 tpi-JET Chip with 305 tpi prom?
Yes it probably will work but depends on what the jet chip was programmed for with respect to injectors and such. The knock sensor may be a problem perhaps as you are using the esc filter for a 305 with a sensor for a 350 but as long as you don't get too many knock counts you should be Ok. Maybe someone else sees some problem?
BlueIroc-Z
06-09-2019 03:22 AM
drewdock87
South Central
08-18-2015 09:02 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: 350 tpi-JET Chip with 305 tpi prom?
