How difficult to replace transmission lines?
Old 02-27-2012, 02:43 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Hey guys, how hard it is to replace the metal lines for my tranny? One of my lines is Already leaking so I went ahead and bought two six ft lines to replace them but I'm wanting to know just what I have to look forward too, I know I have to bend the lines and I have a line bender so help please.
Old 02-27-2012, 03:57 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
Re: How difficult to replace transmission lines?
i dont want to sound like a noob but i am,can you use rubber hose for the tranny cooler lines
Old 02-27-2012, 03:59 PM
Engine: L31 350
You can but I wouldn't advise it
Old 02-27-2012, 06:57 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
This is one of the first repairs I had to make to my car when I got it. Job itself is fairly simple. Amount of room to work is tight. Lower the trans as far was you can safely. Helps to take the distributor cap off so you dont crack it when the engine tilts. Should give you just enough room to get a wrench on the fittings. Unscrew from the tranny, unscrew from the radiator, and install the new lines.
As for the rubber line question. I replaced my lines with rubber and never had an issue. Ran the car for about a year this way before parking it for its rebuild. People say its fine to do others disagree. The pressure in the lines isn't great so if you do it just be safe and double hose clamp each end.
Old 02-27-2012, 07:33 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
It seams I remove and install these with the tranny and engine in the car about once a year. The first go around when bending the new lines could be difficult getting the fittings to line up on the tranny but its doable. Get ready for some bloody knuckles.
Old 02-27-2012, 07:36 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I was thinking about using rubber so I went to our local hydro shop and talked to them. They had the right hose and fittings just needed to know how long I wanted them. I decided to make my own out of brake lines, I would go under the car and measure were I needed to put bends and took my time and bend the pipe. Turned out pretty nice.
Old 02-27-2012, 07:37 PM
Engine: L31 350
why do you do this every year?
Old 02-27-2012, 07:40 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
its so easy its hard
the worst part is getting them to line up so you can attach them
Im replacing mine with braided stainless when I swap out my trans again
Vintageracer
01-10-2020 05:33 PM
theshackle
03-05-2017 06:37 PM
Reddeath210
10-06-2015 08:20 AM
mizz0313
08-12-2015 06:45 AM
MustangEater82
Brakes
08-11-2015 07:52 AM
Quick Reply: How difficult to replace transmission lines?
