Transmission line length and size.
Old 02-15-2012, 04:42 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
One of my lines is leaking that connects to the trans and i just want to replace both lines since ones leaking. Can anyone tell me the length I need and the size of the line?
Old 02-15-2012, 06:16 PM
ex-x-fire's Avatar
Re: Transmission line length and size.
Should be 5/16, your gonna have to measure the length. It might be easier to use 2 lines per side w/ a union. You'll need a tubing bender to make those tight bends.
Old 02-15-2012, 06:37 PM
Engine: L31 350
Iv got a tube bender so that no problem and I Want a full solid line. Less chance for a leak
Old 02-15-2012, 07:27 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I went to Carquest and bought the longest brake lines they had and made it in one piece.
Old 02-15-2012, 07:50 PM
Engine: L31 350
Longest is 6 ft
Old 02-15-2012, 08:23 PM
Edwardgp's Avatar
Engine: 454-350
That was long enough to mine in one piece and it did surprise me!
Old 02-15-2012, 09:38 PM
Engine: L31 350
I there's 6 feet from thr radiator or the tranny? Wow
Old 02-17-2012, 06:30 PM
Engine: L31 350
okay i called and got prices for the line, its $8 for each 6 ft metal line, but they dont carry new end peices, the type that screw into the tranny and the radaitor, where can i get these or what other types of cars do they run on?
Old 02-17-2012, 06:37 PM
Edwardgp's Avatar
Engine: 454-350
I thought I saw those fittings on e-bay or a Transmission shop could help you.
Old 02-17-2012, 06:39 PM
Engine: L31 350
do fourth gens use the same size fittings?
Old 02-17-2012, 07:14 PM
ex-x-fire's Avatar
I'm pretty sure those fittings on the new lines are the same thread as your oem lines, if not then just reflare them w/ your oem fittings.
AussiePr0nCar
03-06-2020 04:04 PM
midge54
12-27-2019 04:14 PM
Reddeath210
10-06-2015 08:20 AM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Transmission line length and size.
