383 with vortec heads question
Old 02-13-2012, 12:03 PM
AJHECK95's Avatar
Car: 1989 formula
Engine: stock lo3 305
Axle/Gears: dont know
can i just put vortec heads on a 383 or do i have to machine anything
Old 02-13-2012, 01:50 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: 383 with vortec heads question
The Vortec heads will bolt right onto any Gen 1 SBC (the steam holes for a 400 block would be the only consideration).
The head-to-intake bolt pattern is what's unique for Vortec heads.
Old 02-13-2012, 02:01 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
They will bolt on to your block, but you will still have the same valve-lift limit (around 0.460") of the Vortec head unless that is corrected, and due to the relatively small CSA of the Vortec intake port you may be a little RPM limited (power wise) on a 383. It's not bad for street driving, but for best track results some careful porting would be in order.
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
10-29-2022 09:20 PM
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 383 with vortec heads question
