Lucas Oil Stabilizer Fail!!! DO NOT BUY!!!
Old 01-15-2012, 09:57 AM
ckyfreak2010's Avatar
made this video at work the other day, finally showing that lucas oil stabilizer is junk...hopefully this changes your mind on buying it, if the though ever crossed your mind
http://www.youtube.com/watch?v=rjHPTjDshyg
Old 01-15-2012, 10:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Lucas Oil Stabilizer Fail!!! DO NOT BUY!!!
I noticed the bubbles years ago just by turning the crank handle, so I've never used the stuff.
Thanks for posting the vid. I shared it.
Old 01-15-2012, 10:19 AM
yeah there are some bubbles created just from turning it, but most people wont be discouraged by it unfortunately.....and no problem for maken the vid, and thanks for sharing it
Old 01-21-2012, 12:02 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Man, I just tried this first time ever about two weeks ago... right before your post!
Not that I'm an expert by any means but engine oil is tested using 6 or so different tests for stuff like sheer of the oil itself, time versus parts damage, heat resistance and more. It would be interesting to read lab test results. One thing I noticed, my oil pressure is higher using this stuff. Hope I'm okay for mostly short trips/gas saving way I drive but your right, the video is pretty concerning.
Old 01-22-2012, 07:41 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Ok... some real scientific testing? Based on those results if we ran an 80/20 mix in our engine the oil would foam out the filler cap? How do we know if there is actually Lucas product in that thing? Look, a counter top prop is not reason enough to dismiss the product.... it's not reason enough to buy it either. I think all oil additives are snake oil.
Old 01-22-2012, 07:59 PM
cerberus's Avatar
Car: 1985 IROC
the most poorly unscientific test I have ever seen yet.
Old 01-22-2012, 08:45 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
why is it that i NEVER see any trace of foam on my dipstick whenever i check the oil in my truck? i use lucas oil stabalizer every single oil change in my daily drivers. i've never once seen any foam in under the valve covers or on the dipstick. this "test" implies that i would see it not only with the engine running, but up to an hour+ after i shut it off. never, not once have i seen it. ontop of that, i have less cold start "noises" out of both the 5.3 in my truck, and the 2.0 in the wife's neon (which have notorious issues with cold start noises from the timing belt tensioner), and the oil seems to stay cleaner longer. i check my oil every time i fill up. neither engine use or leak a drop either.
you guys can not claim that lucas is bad, just cause you hooked a drill to a plastic display
Old 01-22-2012, 08:52 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
+1
The following 2 users liked this post by sailtexas186548:
gregg64 (08-05-2019), SMH (10-28-2021)
Old 01-27-2012, 07:03 PM
Ihavenosoul's Avatar
Car: 84 Z28
Engine: 305 HO
in your engine no it will not foam up there is no part that can mix the air in like the teeth on the gear. besides it is dilluted with regular oil. just thickens it up running 20w50 does the same as running lucas with 5w30. by using it on a lower mileage engine it actually forces the bearings to wear out enough to allow it to flow properly. then you really cannot go back to regular weight oil due to the slack that is now in the bearings. but years or being in the oil change business showed me that you do not want to put it in your manual transmission or differential as you can tell if it has it because it looks like chocolate milk same color as a blown head gasket due to the air in it.
Old 01-27-2012, 07:53 PM
lemons racer's Avatar
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
Anyone that buys snake oil or same such products ( the tornado for example) deserves them, fools will always buy this crap and always will.
What pisses me off is I'm not underhanded enough to take money from suckers!
Old 01-27-2012, 11:08 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
The gear set counter top test is a great example to show how it helps the oil not break down as quickly, and increases the viscosity.
However, using the gear set in high rpm's is not a good test because that DOES NOT simulate how an engine operates. There's no gear mesh in an engine like the simulator, hell there's not even any heat... In an engine the oil pump picks it up at the bottom, it runs through the valleys into the crank journals/piston mains, and up to the heads....
Some key points:
- Gear mesh pickup is nonexistent in an engine.
- The amount of liquid in that tester is FARRR less than what would be in an engine. That means, the tester would break down MUCH faster than a test with 5 qts or oil + stabilizer.
- How OLD do you think that simulator is exactly? Unless that oil was changed 5 months ago, it's not accurate.
I've used lucas for years, never had a problem, and often times helped reduce oil burning, and I even added it in a car AFTER I blew a rear main seal, kept my car going, leaking oil like crazy for 7months, but my engine lasted because of it.
The product is good, otherwise it would not have lasted for so long with such a great reputation.
Anyone that honestly takes this test to heart to prove the product's effectiveness is very poorly educated, or just wants to jump on the bandwagon of thinking they found something new, which they did not. If anything, this proves the video makers are idiots, which a majority of people are that work at part stores...(usually the kids).
My question is.... how many times have you received the WRONG part at a part store? And are you seriously going to believe "evidence" from those same individuals? It's ludicrous.
Old 01-27-2012, 11:47 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
i see it doing it's Job. climbing all the way to the top gear. even under Hi RPM.
so you got some air mixed with it.. your oil pump works in a diff way then dragn/dipping into a oil bath.
the eng oil pump works by pulling then pushing into a tube. and not mixing with AIR. when doing so..
if it did mix with air. your oil pump is starving for Oil. and that is a NO NO anyway..= Fail!!
you guys need to think this one over
OIL PUMP PICK UP..is under oil.
by 2 to 3" in a stock eng when running. picking up NO AIR!
YOU SEE WHEN IT DOSE PICK UP AIR.
EXMPL
YOU will have lifter tick tick tick. from low oil presh.(IN MOST STOCK ENGS)
has air will compress.. and oil will not..no liquid will (just a side note)
this is how a oil pump works..by pushing into a tube
NOT..RINNING IN A BATH..Hope this helps ya..
kids... BUY THEM BOOKS AND BUY THEM BOOKS!
what do they do?..eat the teacher!
Old 01-27-2012, 11:53 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Just curious has anyone used Lucas tranny sealer? I have a tranny leak on the front seal. Someone said the stuff is great. I have not used it yet, because waiting for the tranny fluid to get lower.
Old 01-28-2012, 06:27 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You said it yourself...right in the video. "But oil in engines is circulated by and oil pump and gravity, not spinning gears..."
The same logic applies to why the lucas side acts as it acts.
Btw...I work at a parts store. I cant stand it. Its a second job to make some extra cash. The reason I cant stand it..my co-workers. Caught a kid the other day hooking a starter to the tester. He had the postive on the solenoid positive, and was hooking the negative to the OTHER BIG POST on the starter... Awesome.
When I worked for the same store years and years ago, we broke one of those testers open. I dont even know if you can call whats in there oil in the first place... But I do know Lucas has been around quite a while. And lots of guys swear by it. I sell it by the truck loads.
J.
Old 01-28-2012, 09:01 PM
mw66nova's Avatar
Engine: 7.0L
^^i too work at a parts store part time while i finish my degree. i typically steer folks away from products i don't believe in.
i sell lucas products, seafoam, and white shepard/blue devil sealers. i've seen all of them do everything they claim, and i believe in them as long as the directions are followed properly.
snake oil schmake oil, there is some no kidding chemical engineering going on in some of the products today, and the average consumer is no longer just "throwing it in the engine because nascar uses it" (ie zmax and other dumb additives that feed off of a consumers LACK of knowledge)
Old 01-29-2012, 12:54 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Unfortunately I'm forced to buy 20w50 Synthetic Royal Purple oil for my Camaro...Whoever the prior owners were beat the engine to hell and back, and anything LESS than what I use makes the engine knock/tick on startup, ( Yes, I've tested other oil visc.) Even in really cold conditions the 20w50 isn't enough at times, I've done 3 Oil changes since having the car, with the 20w50 Synthetic, and Once WITH the lucas oil additive, With the additive in the car, I never once had the engine knock, even on a cold day, and it runs smoother when starting up from a stop light. The 20w50syn works fine, but I'd much rather have Lucas added to avoid those very rare, but occasional knocks/ticks in the AM. It costs a butt load to do an oil change but it's worth it to have my car drivable. (Approximately $70-80)
Old 01-29-2012, 01:23 PM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
I have ran this stuff for years and never had any problems. Started buying the stuff when I picked up a s10 with a 2.2 for a DD. Previous owner blew head gasket and ran it for a while with milky oil. I use Lucas with the cheapest oil I can find when it comes time for an oil change, and have put over 65,000 miles with no problems, ticks, or leaks.
Old 02-06-2012, 02:40 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
Ive used it on my gen 1 sbc motors that were built and had good mileage on them..It did work well..quieted valve train noise..burned less oil etc.my oil changes started to come out rather clean aswell.As for my hile mileage ls1...did not take to the lucas stuff well..at all.I added maybe qtr of the bottle to my motor and let it sit for 15mins.Apon restarting the car..it began to burn oil more..raised my oil pressure and car became sluggish downlow.Good thing Im swapping motors soon anyway but i soon drained the oil and replaced it again with fresh amsoil and it got better..still not 100%.
Years ago I would recommend this product but today with the highly developed oils being made..its easier to just use a thicker heavier oil without changing the characteristics of the oil already in your motor with additives.Do regular oil changes with quality oil will do you better than relying on over the counter remedy in a bottle,just my opinion.
Old 02-06-2012, 09:10 PM
RSCAMAROGUY91's Avatar
Car: 1991 RS Camaro w/ Factory T-Tops
Engine: Built 355 ci SBC w/ Carb
Transmission: Borg Warner T-5
Axle/Gears: 4.10 with Posi-Trac
Did you use the Synthetic in your LS1? On the newer engines the Synthetic would probably be a better choice. Best I remember the Synthetic Lucas isn't as thick, and is better suited for newer vehicles. But I've used Lucas Oil products in several of my projects including my Camaro, and have never had any problems.
Old 02-06-2012, 09:35 PM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
i always though the stuff makes ur engine work harder...its like pouring honey down ur oil filler
Old 02-10-2012, 11:30 PM
Engine: 2005 LQ4
Axle/Gears: 3:42
I am using synthetic oil and the lucas stuff is exactly like pouring out honey.Thicker than oil for sure.Ive seen alot of guys stay far away from it with built motors and only used it on something high mileage that is already showings signs for a rebuild.I doesnt make the engine work harder..cant say the same for your oil pump with people reporting almost 20psi higher oil pressure at idle.
Old 02-19-2012, 08:07 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Looks like the original poster has a beef with Lucas or too much time on his hands, or both. I have used Lucas products for years and never had the first issue as it appears most everybody else has had the same results. I say if you don't like them, don't use them, but if you are going to do a test, please, don't post it on youtube for everyone to see how completely unscientific and laughable it is.
Old 02-19-2012, 12:30 PM
71nova's Avatar
Car: 1990 Iroc Z
Axle/Gears: 9 bolt
I've used Lucas in my Nova's .040 over 350 engine since I built it 8 years ago. Have made over 150 1/4 mile passes at the track and about 10,000 miles on the street flogging it like a dog shifting at 7000+ rpm made 22 passes down track in 1 night. I don't no if the stabilizer is good or bad but the oil stays very clean, lasts longer, oil pressure is a little higher and my track times have consistently gotten better with a best of 12.17 on a bfg 225/45/17 drag radial.
Old 02-21-2012, 09:08 AM
BOOT77's Avatar
I don't know if any1 said it cause I just skimmed but GEAR DRIVE or rearend. Also I'm pretty sure the oil pumps oil with gears.
edit: Also what bout the cam/dist gears
Old 02-21-2012, 11:16 AM
mw66nova's Avatar
Engine: 7.0L
Those gears are typically splash lubed, so no big deal I'd they get a little air in there.
Old 02-24-2012, 10:35 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I too call BS on the OP's claim. Started 1 quart lucas with 3 quarts High Mileage oil when I bought the car with 180,xxx miles. Every oil change gets it. Along with Lucas injector cleaner every couple tanks of fuel. Now at 240,xxx miles and the car runs like brand new. 2.8 V6, but I don't think that makes a difference when talking Lucas products.
I think that alone blows the OP's claim out of the water. Besides the fact that the little gear thing at all the auto parts store is made to show that lucas added to regular oil, will help it to get EVERYWHERE in the motor and coat parts better than just oil alone.
Lucas is highly recommended by me and many others.
IMO Lucas anything is worth the money. Used some of the Lucas Stop Slip in my trans when I was having problems with it; Haven't had a problem with the trans since. All depends on how bad the leak/seal is.
Old 08-11-2016, 05:28 PM
petestud3's Avatar
I have a 2009 Chrysler Aspen with 167,000 miles on it now. When we bought this it was previously a rental vehicle. This vehicle uses 5W20, so it is already thin.
It always had a bad tick even in the summer, but really bad in the winter. And it started hard in the winter as anyone would expect a vehicle to.
Over the last year I started using Lucas in my oil and it quieted down the tick very much when it started cold and then went away within seconds. I did not lose any power whatsoever and there has never been any foam or weird oil problems. And my oil is even dark when I change it knowing that the detergents in the oil are doing their job. Plus the engine turns right over on a cold start.
Sure it is a little pricey, but it sure makes a positive difference in my engine.
Old 08-11-2016, 06:11 PM
mw66nova's Avatar
Engine: 7.0L
did you just make a username and resurrect an old thread to talk about your Aspen on a thirdgen site?
ugh....go away bot.
Old 08-11-2016, 06:17 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Old 08-11-2016, 08:32 PM
petestud3's Avatar
Well I guess I didn't look at the date. My bad.
Old 08-11-2016, 08:34 PM
petestud3's Avatar
As a matter of fact, I don't even know why I'm on this site. It has nothing pertaining to what I drive. I will have to pay more attention next time.
Old 08-12-2016, 08:43 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Lol. Heres my story. I blew both headgaskets and wiped all the bearings in the motor. As I nursed it into autozone I bought this lucas oil stabilizer. Thought what the hell, Im waiting on a tow couldnt hurt to try. Poured it in, turned the key,,,,wow started right up. Purred like a cat and gained 50hp easily. Canceled the tow, drove it home. That was 5 years ago. Still driving it today. Looked at the engine the other day. Was surprised it now has aluminum heads and a dart block. This not only fixed my motor but transformed it into somthing better. I was blown away!Highly recommended.
Old 09-03-2016, 11:37 PM
Davem's Avatar
Have a 3.3 plymouth with 260000 miles and it knocks without Lucas have used it several times and it works for me davem
Old 09-04-2016, 12:02 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Well I don't care how old the thread is I want to know does the stuff work or not.
Old 09-04-2016, 01:04 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Yes it does.
Old 09-04-2016, 04:10 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks for the reply IrocZ1989.Can you give me more info, have you used the stuff personally?
Old 11-10-2017, 04:49 PM
PSamson's Avatar
i was upsold on an oil change and my car blew up. I'm told it's not for BMW. Called the oil change place and compared it to honey as well. They tried to bs me until I brought up my mechanic and talked about oil pressure and viscosity. They really do treat women like idiots. It's sad.
Old 11-11-2017, 06:58 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
FOOLS that buy that SNAKE OIL!
Old 11-11-2017, 09:42 PM
joshc's Avatar
Car: 1986 Trans Am
Someone from Bobistheoilguy.com sent some in for analysis.
https://bobistheoilguy.com/forums/ub...pics/1976391/1
Not impressive at all, just thick low grade oil with no anti wear, detergent or anti foam additives.
You are actually diluting the additive package that is already in any decent oil and making it worse.
If you have a worn out engine and need a thick oil, just buy some 20w50 and leave it alone!
Old 01-24-2018, 08:12 PM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
I did an oil change once on my 76 Pontiac gp. 5 quarts of 10w30 and one quart of lucas. Took an afternoon drive to the jersey shore. you should have heard the lifters clattering all the way there and back. got home, dropped a quart of oil out of the pan and put another quart of 10w30 in the engine. never heard another lifter clatter after that. never used that stuff again.
Old 08-05-2019, 12:24 AM
Brian Laycox's Avatar
So by this rationale, I could drink the stuff and in time, I will grow 5 inches taller and my wangster will grow 3 more inches? Awesome! The first part of your story intrigued me, but then I figured it was smoke up my *** when you said it performed a miracle and transformed physical matter into something better than what you had prior. Good chuckle though. Had me going for a minute. I just put it in my 89 305 ton with 51k miles and a bit of a burning prob. I get a puff at startup and if I idle I'm noticing more smoke. I've only had the car since 49k miles and I assume the previous owner beat her down good for those 49k. So.... so far, since the addition to lucas, I barely get a puff at startup. I get no smoke at idle, and the exhaust fumes smell more "clean" if there is such a thing. It smelled like a skunk's taint before. The oil pressure gauge has increased slightly, the idle sounds a bit deeper from the exhaust, and I feel like my little 305 has a tad more pep...but not much. It probably helped restore some of the lost hp due to the weak seals. I poured it into a half cooled engine. Thick! It's cool when it becomes mixed in, you can actually hear the engine sound like it gained 10mg of testosterone...in its voice. I'm not claiming miracles, but I did notice some differences. I'm not gonna swap our the engine unless it becomes unbearable or I cant see the car behind me through the smoke. Right now we are all good.
Old 08-05-2019, 07:35 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
I dont know how the transformation works or the time it takes to complete but I do know its prominent and random. I'll give you some examples. Another friend did this as well. He parked the car for 2 weeks. When he decided to take it out of the garage a quick pop of the hood almost knocked him off his feet. Not only was the high mileage L98 not there, in its place was a 427 LS awap. He was stunned. Another acquaintance had a simaler experience. In his situation he let the car sit 3 weeks and low and behold a 502 big block was there when the hood was opened. It's totally random but mind blowing at the same time. A word of caution. You have to buy the Lucas brand, not the store brand copy for this to work in your favor. A example of this is one of my good friends. Feel bad for him after this experience. He thought he would save a few dollars over the Lucas and on top of that have his totally transformed engine for a fraction of the cost we fools who bought the Lucas paid more for.So he pours the store brand in and proceeds to park it in the garage for a month. He was counting the days to what he would end up with. He couldn't contain his excitement the last day. He called us all up and said he was popping the hood the next day and we should all be there for the big reveal. Next day comes and we all gather round to ponder what will become of the store brand Lucas copy oil treatment. He pops the hood and good thing we were all around to catch him when he fainted. In place of his L98 was a 4 cylinder Iron Duke. Rusted block, tin all pitted and rusted. Leaking valve cover. What a shock. He has not been the same since. I have not talked to him since he went upstate when he lost his mind. So word to the wise. Use the name brand Lucas and not the store brand copy. Its guaranteed to knock your socks off.
The following 2 users liked this post by IROCZ1989:
83AQ9 (08-11-2019), WildCard600 (08-05-2019)
Old 08-05-2019, 11:15 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Thanks for posting that! It's great to know what is actually in it and be able to make informed decisions.
Old 08-05-2019, 03:13 PM
I'm dying! I hope my 305 turns into a big block and that it fits perfectly lol. Heres to hoping!
Old 08-06-2019, 09:55 AM
ploegi's Avatar
Engine: 5.7 TPI
Ok, that wasn't what I expected..... though, certainly good for a laugh.
Some folks swear by this stuff, other folks swear at it..... it's pretty much the same argument over which is better, dino oil, or synthetic? I suppose it depends on why you are using it, and what your expectations are. Would I dump thick oil into an engine that wants 0w20? Notta chance..... but, if I wanted to milk a bit more life out of a worn out v-8, I may consider it......
Old 08-11-2019, 12:28 PM
83AQ9's Avatar
Car: 1983 Recaro T/A
Engine: GMPP 350HO Carbed
They put that little thing in the store where the oil climbs the gears, but you don't actually want your oil to do that. Thin film lubrication is how engine oil works. Making it a thick film doesn't help. The main thing you'll achieve by using that stuff is creating fluid shear, which breaks down the polymer chains in the oil that allow it to thicken when warm. So your 15W40 thins out to just 15W or less even faster. The engine is designed to distribute oil that doesn't stick together like that so other problems like lack of lubrication to some areas, minor foaming, cavitation, and small unbalances on rotating parts are in theory a possible problem if you take it way too far. The only problems you are likely to really see are a small loss in power and faster oil breakdown.
If you need to thicken your oil slightly just mix weights of a quality oil. Pour in half 15W40 and half 20W50, now you've got 17.5W45.
Old 07-20-2022, 12:22 AM
ugh....go away bot.
I'm just logging in to resurrect this old post AGAIN just to irritate you. People come HERE for help dude. Something written 100 years ago might help someone today so don't be such a stick in the mud. Good morning btw.
QwkTrip
10-13-2021 12:08 PM
Air_Adam
126
03-25-2013 11:44 AM
BORLAZ06
07-28-2008 04:37 AM
redbird_400
04-19-2002 02:22 PM
JT 85 TA 305
04-08-2002 06:19 AM
Quick Reply: Lucas Oil Stabilizer Fail!!! DO NOT BUY!!!
