C4 ??? 1LE ???
Old 01-02-2012, 10:10 PM
aheld13's Avatar
C4 ??? 1LE ???
OK C4 corvette brake calipers are basiclly the same as 89-92 1LE CAMARO caliper? what i want to know is if the mounting brakets are the same?
what im thinking about doing is running the 1LE rotor and C4 calipers
the C4 calipers are way cheaper and easy to find compared to the 1LE
Old 01-03-2012, 05:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: C4 ??? 1LE ???
i think the caliper is the same, but the abutment is different.
Old 01-03-2012, 06:42 PM
aheld13's Avatar
Re: C4 ??? 1LE ???
thats what im thinking too... but not 100% sure
but im sure i can machine a bracket to mount to the spindle but it would save me time if the same bracket as the 1LE would work
Old 06-17-2012, 01:37 PM
frederzick's Avatar
Car: 1991 Camaro Z-28
Transmission: Automatic
Axle/Gears: 2.73:1
Re: C4 ??? 1LE ???
I looked the calipers and the brake pads up on Advance Auto Parts web-site, while the calipers have a different location that the brake hose connects too the brake pads they use are the same. I don't see why there would be any difference in the abutment plate as long as everything else you have is 1LE I think the C4 calipers would work just fine. Though your not really saving all that much in cost, but every penny counts. I'm currently building the 1LE brake set-up for my car as well, though I've ordered two set's of the 1LE calipers for the front now, to try and get a perfect match, since they are re-manufactured, you never know what your going to get. I now have two that match perfectly. Your question has brought about yet another question, just now what is the difference with the heavy duty over the standard corvette caliper.
Old 06-17-2012, 01:53 PM
Jeffs82TA's Avatar
Re: C4 ??? 1LE ???
heavy duty is 13" front rotors with a bit different caliper with different mounting abutment plates
standard is 12" and thinner front rotors
backs are the same though
heavy duty on left standard on right
heavy duty caliper
standard caliper (notice where the standard caliper is flat the heavy duty is curved)
Old 06-18-2012, 07:19 PM
frederzick's Avatar
Axle/Gears: 2.73:1
Re: C4 ??? 1LE ???
I can clearly see the differences in the rotors and the rounded portion of the heavy duty, just curious though if you used all 1LE parts then wouldn't any of the calipers be interchangeable since they all use the same pads, atleast according to advance auto parts web site.
*also just to note looking at the 1LE caliper, it is rounded just like the heavy duty vette caliper.
Old 06-20-2012, 06:03 AM
frederzick's Avatar
Axle/Gears: 2.73:1
Re: C4 ??? 1LE ???
So basically it sounds/looks like the calipers are interchangable, but you would need to stick with the 1LE carriers/ spindle brackets along with rotors, though I have seen a spindle bracket on eBay that allows you to attach different carriers/calipers, I don't remember what though. Also in my online searching I found a guide on installing the heavy duty c4 brake setup as well as other options. Have to look it up when I get home and put the link on here.
Old 06-20-2012, 07:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: C4 ??? 1LE ???
I'm not sure which C4 caliper you are referring to. But the standard duty ones aren't wide enough to fit over the thicker rotors.
RBob.
Old 06-25-2012, 10:55 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: C4 ??? 1LE ???
RBob.
Exactly. I went through this before with Ed. He explained it to me the same way. The HD setup uses a beefier rotor. I may upgrade in the future.
Old 06-30-2012, 10:29 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Re: C4 ??? 1LE ???
Just Did this look at my earlier post this is using the Baer brakes version of the HD C4 caliper
https://www.thirdgen.org/forums/brak...ml#post5315713
Vintageracer
01-10-2020 05:33 PM
PurelyPMD
05-05-2016 04:57 PM
87v6Bird
Brakes
10-04-2015 07:37 AM
mcgarnicle
09-24-2015 07:18 PM
Necron
Brakes
09-14-2015 12:45 PM
Quick Reply: C4 ??? 1LE ???
