Edelbrock High Flow Intake Manifold Issue..
Old 12-16-2011, 09:56 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi guys. Here is another confusing situation. I have a EDL-3860 High Flow intake base. I noticed that there was 2 different EDL-3860 intake bases. One has the fitting on the driverside which a hose connects to for the PCV valve on the driverside. The other (mine) has no hole for a fitting for the PCV Valve hose. So what the heck am I supposed to do? Could I run a "T" inbetween the brake booster and the plenum so that the vacuum can pull out the crank case fumes?
Top picture is mine (yellow arrow)....
edl3860.jpg?t=1324093426
Here is the fitting that is used to connect a PVC hose.
topvc.jpg?t=1324093772
Old 12-16-2011, 10:00 PM
Re: Edelbrock High Flow Intake Manifold Issue..
And here is my current setup with the PVC hose which connects to the existing fitting on my OEM intake base...
1324094292.jpg?t=1324094390
Old 12-16-2011, 11:06 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
It's a PCV valve not a PVC. PVC is like plastic pipe or whatever.
Just saying as it might help having the abbreviations correct if you are trying to search for your answer.
Honestly, I am stumped. I have no clue why it wouldn't have it. Maybe one of them is for a MAF car and one is for a MAP car?
Old 12-16-2011, 11:50 PM
OOps. Thats what I was thinking too but both styles use the very same ID # of 3860.
Old 12-17-2011, 10:36 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Locate the vacuum passage in the manifold base, then drill and tap for a fitting.
I had a GM base like that awhile back. Dont know exactly why it was done. BUT...
If you want to get around it, just dont run the PCV, install a breather on each side, and cap the supply from the other valve cover on the passenger side of the throttle body.
Old 12-17-2011, 11:04 AM
So then if I put breathers on both valve covers, the positive pressure from the blow by gasses will of course vent via the breathers right?
Old 12-17-2011, 12:41 PM
dhirocz's Avatar
Right. The stock system provides a supply into the crankcase from the throttlebody, then returns into the intake through the PCV for burning. It's mostly for emissions purposes, burning vapors in the crankcase. The stock system uses metered air so you could just bypass it with the method I mentioned above.
If you eliminate the supply from the TB or the PCV you have to eliminate the other. Otherwise, you would be creating a hell of a vacuum leak. Just eliminate both and install breathers. Done deal
Old 12-17-2011, 02:45 PM
Noted. Thanks guys. I appreciate the info.
Old 12-17-2011, 03:13 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You can tap into full manifold vacuum in the plenum or in the cold-start passage in the manifold base.
Getting rid of the PCV will change the needed IAC calibrations, minimum air rate, MAF calibration for idle, and probably require a small adjustment to your TPS.
It's not that big of a deal to do, and only necessary if you aren't happy with your idle after the change.
No PCV will also cause your engine oil to become contaminated with moisture and fuel quicker, so you might have to adjust your oil change schedule a bit too.
Old 12-17-2011, 03:19 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
If you're car gets a visual inspection for emmissions equipment you'll probably get fined for the breather. That's the case here. $150 fine for us and we get roadside checks. Something to think about.
Old 12-17-2011, 03:33 PM
I've never cut open nor do I know the internal sections of the intake base. So is the cold start section utilize the same chamber as nozzle on the later EDL intake manifolds?
Old 12-17-2011, 05:27 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The factory vacuum port connects directly to the hole where the cold-start injector fires, - driver-side.
Just drill & tap as close to the cold-start hole as you can without causing a problem, and add a vacuum port. Check your runners flange to see if it has space for this.
If you don't want to modify the runner flange or base, then just pick up the passage where it runs under the plenum and drill & tap there. At that point, you might as well just drill into the bottom of your plenum space to add the port.
Old 12-17-2011, 06:11 PM
Tap under the plenum? Sounds like a good idea. But won't I begin to get a lot of oil residue mixed with some exhaust soot (egr ports) in the plenum and runners?
Old 12-17-2011, 06:15 PM
Honostly, I'm about ready to sell this ported intake base and buy another used one with the port or trade for one that already has the vacuum port. I mean, there is a lot of people who remove all egr and emissions equipment. I'm just tired of dealing with this issue all together.
Old 12-18-2011, 11:32 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Here is the way SLP did it on the early base.
Attached Thumbnails Edelbrock High Flow Intake Manifold Issue..-edl-3870-fitting.jpg
Old 12-18-2011, 01:24 PM
dhirocz's Avatar
Well if you want to run the PCV valve. Just drill and tap. Pick your location and break out the drill bits.
Forgot about the cali smog thing. Forgot that they are doing that there. Last time I lived there, they werent as aggressive about things as they are now. It's rediculous.
Old 12-18-2011, 06:58 PM
Tap and drill the plenum is an option that I may consider, heavily. But what about this idea? Could I put an inline T connector in between the TB and the EVAP Cannister?
vaclineformyiroc.jpg?t=1324255947
Looks so much easier.
Old 12-18-2011, 07:01 PM
I have the 9th injector fuel rail which I plan to use. But that is a good point too. Using the ninth injector section of the lower runner.
Old 12-19-2011, 04:08 PM
Bump.
Old 12-19-2011, 04:14 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would get rid of the 9th injector and go to 89 $6E reprogramming and drill and tap this block off are ask them if they will.
http://www.ebay.com/itm/CHEVY-TPI-CO...ht_1089wt_1055
Old 12-19-2011, 07:34 PM
89 Camaro? Which MemCal or PROM BIN should I use if I do delete the CS injector?
Prom BCC Prom Code* Scan ID* Trans Gear Ratio Emissions * Body
AUJM 0580 0551 Auto 3.27 Fed **** F
AUJN 0584 0561 Auto 3.27 Fed **** F
APYU 3516 3531 Auto 3.27 Fed **** F
ARAD 4868 3881 Auto 3.27 Fed ***** F
ANYF 9356 9362 Auto 3.27 Fed ***** F
Old 12-19-2011, 07:37 PM
Engine: Lb9
Transmission: M20
bcc decoder is a chevythunder.com the 89 has vats so you can install the bypass module for $14 on ebay. or you can use your own and do a piggybackchip. tpiparts.net
Old 12-19-2011, 08:02 PM
Currently I have a 86 MemCal which is connected to a Moates G-1 adapter. The EPROM has a 87 BIN File which supports the 350 block. I needed this because the MemCal has a 305 LB9 BIN File. so then all I need is a 89 Bin file right? I just wanna fill in all the holes before I start spending money or ask some friends to program a EPROM for free. So since I have a Moates G-1 adapter, what else would I need?
Old 12-19-2011, 08:09 PM
Engine: Lb9
Transmission: M20
yes a 27c128 or 27c256 ect programed without vats on the g1 will work just remove vats arar arap work even though they are agressive on timing. let me know if you need any .bins
Old 12-19-2011, 08:17 PM
I could probably find the bin in the BIN bank over on Moates.com. But I you have one of the 89 IROC 350 3.27 Auto, then that would be cool. By any chance, would you be able to prep the bin for me?
Old 12-19-2011, 09:11 PM
Engine: Lb9
Transmission: M20
pm me with your email and engine combination.
Old 12-20-2011, 05:42 PM
Davejs's Avatar
Engines do need that vacuum to run properly, high horse power engines even run vacuum pumps to scavage crank case vacuum. I'm not talking about street cars either some big power guys run them when they could bypass it. Pressure leaking around the pistons supplies the pressure that slows an engine down if not removed.
Old 02-11-2013, 02:31 PM
Copperhead's Avatar
Originally Posted by dhirocz
The stock system provides a supply into the crankcase from the throttlebody . . .
Back from the dead, tracking a low vacuum issue in my 383 TPI build...it's running about 7-8" vacuum, with no leaks evident.
Where does the above-mentioned supply run from on the TB, and where to?
Also, what are the big red B and C ports for in Post #1 above? My B is currently blocked off and my vac brake booster is plugged into C. Will this work properly, or is this possibly part of my problem?
Old 02-11-2013, 04:59 PM
Engine: Lb9
Transmission: M20
on the top pic B is used on 85-88 tpi and is manifold vacuum passage for the 9th csi. C is for corvette rear exhaust feed for the egr. Your vacuum booster gets feed off the lh rear plenum fitting, the pcv is where the yellow arrow is pointing.
Old 02-12-2013, 07:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
B is manifold vacuum passage for the 9th csi.
C is for corvette rear exhaust feed for the egr..
Other way around
Old 02-12-2013, 07:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Air from TB port to pass side cover , out PCV valve on drv side cover to the port you have your booster hose on
As noted booster should be from large port at rear of plenum
Simplified TPI vac system
Old 02-12-2013, 07:52 PM
Engine: Lb9
Transmission: M20
Originally Posted by vetteoz
Other way around
yeh, I couldn't see the pic when I was posting b , c same thing
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
theurge
08-21-2015 12:46 PM
Dialed_In
08-20-2015 01:45 PM
86IROC112
08-17-2015 02:00 PM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: Edelbrock High Flow Intake Manifold Issue..
