Skip white performance 427
Re: Skip white performance 427
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I called them up. Talking to them encouraged me NOT to buy the kit.He right away tried to sell me a whole engine then prceeded to tell me they almost got a supercharge 427 to make 600 hp! Um should be doing that without FI. I asked about the deck on the motor and he was not sure what they are decked at. Kinda of a big deal don't ya think.
Any way thats my take. I went with Ohio Crankshaft. I went and visited there shop and talked to Chris. All in all pretty cool guys. Have not started the motor yet but we will see.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I've bought a few items from him without complaint,but it's all been Chinese knockoff stuff.
I personally would be leary of an entire engine kit,as anyone who would sell cheap knockoff stuff,would likely deal in seconds or rejected parts as well.
Just my thoughts.
Just my thoughts.
That's good to know. Defiantly don't want to risk spending 4 grand plus to build a hackjob motor. Kind of seemed too good to be true when I was looking At it. I might have to go lsx then.
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Have you looked into Carl Hinkson of CNC Blocks NE? I've read good things about him. I thinking of using him to build a 420 SBC with a Dart SHP block. He has done a lot of these recently and likes the blocks. Seems he charges around $1,800 to ship a fully machined Dart SHP block. Figure another $1,200 - $2,000 for a rotating assembly installed. His website has been under construction for awhile so best bet is email or call.
At those prices an lsx swap gets more interesting. Also, it seems a 427 out of a normal deck SBC is hard to do as you end up with a small cam. I'm looking to go 3.875" on the stroke instead of 4" to get a 420 ci engine.
http://speedtalk.com/forum/viewtopic...23576&start=15
You sir,are incorrect.Probe Pistons are made in Tennessee,which if you have ever seen a globe,is NOT in China.They are great pistons,only someone who has never inspected a set of them would say otherwise.
I report what is in the trades as a bases as the truth once.Please knock off the childish sarcasm.I don't debate.Skirt sizes vary alot on apond inspection.Found one set with three pistons having hair line cracks.Certainly not Mahle or Wisco.Cheap junk priced as cheap junk.
http://www.probeindustries.com/Articles.asp?ID=1
A LOT of information there to be had before stating "facts".
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Probe pistons are good stuff, try randomly measuring some they will all measure bout the same unlike some of the more popular names. Good for the $
Highly recommended.
Skips an alright guy he sells to a certain crowd though.
Youre not going to get any kind of quality stroker motor for 4k esp. a 427
Figure 2x that.
600hp is a tough nut to crack on most NA smallblocks harder than you think.
Figure 2x that.
It's WISECO.Probe pistons are quality products,UPON inspection.Sofa has had you pinned as an internet expert for a while,I'd have to agree at this point.
To be fair about this the speed industry used to be about the best you could get.Because of customer demands it has become the cheapest imported parts run by false fronted shell companies.The facts are still the same.You do get exactly what you pay for and in some cases alot less.The ad campaigns budgets have grown larger than the materials costs just to convince guys of something that isn't.
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Check out www.cmengines.com. They got some nice engines for super cheap and I've never heard a bad word about them. Everyone I have talked to has loved their purchase and I have also had positive experiances with them just in getting info from them. Have a good one.
I HAD THE SAME EXP WITH SKIP WHITE ONLY WORSE GOT SUCKED INTO A DEAL WITH NO PART NUMBERS AND GOT BOTTOM DOLLAR PIECES HE STATED 600 HP BUT SCAT SAYS 500 AND THE RODS SAID PC SO I THOUGHT PRO COMP SCAT AND GOT CHINESE MADE PRO COMP ELECTRONIC RODS THAT HE SAID (I BEAM) WOULLD GO TO 550 THEY SAID TO ME 475 MAX SO THE NUMBERS ARE ALL WRONG ....BUT I TOOK THE NEXT STEP I HAVE LEARNED MY LESSON JUST MY OPINION BE CAREFUL .... GET PART NUMBERS
Car: 68 camaro
Engine: 427
Axle/Gears: Strange 12 bolt 3.43
Has anyone bought one of skips 427 stage 5 610hp engines recently?
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
old topic but..... anybody bought one of the 427? http://www.ebay.com/itm/SBC-427-DART-MAHLE-SHORT-BLOCK-4340-KIT-4-BOLT-SPLAYED-UNASSEMBLED-/190743695259?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c6935cf9b
Dart shp, Mahle, 4340 crank and rods.... all ballanced...I blow up my 400 and need to buy somethink
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
Have used several of the 383 kits w/ Scat crank,Probe pistons,etc.They have been good kits w/ 0 major problems.Parts measured out good & balance was good as well.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I bought some ProComp heads from them. Ok stuff but I won't be using them on my current build. Looked at their 427's but decided to build locally. If I was going to buy a crate 427 I would go with TriStar engines.
The real world cost for me to build a 421CI small block with Dart block, Callies crank/rods and AFR heads is $9k and I got some "deals" to get there. I know "builders" have mass production and buying power but I can't see how they can offer a motor for $7k without cutting a lot of corners.
If I were doing it all over I would seriously consider the LSX swap. Maybe a little more money in the end but the design is a lot better and emissions are acheavable without all the EGR and AIR appendiges. Just a thought.
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
I bought my 406 from them. Stick with shortblock assy if you do go through them. Like mentioned above, the heads and intake are cheap chinese garbage. I DID buy the long block, regretfully and ended up selling the upper end because i didnt know. I then bought some nice AFR's with a Vic Jr. Intake. Ive beat the crap out of the block and it seems solid! Racing to 6500 without any concern.
If its going on a 87 & up, serpentine system wont bolt to the accessory bolt holes on their heads anyway. Also, determine whether or not their motor would produce enough vacuum. Power brakes needs that. I had to buy a vacuum pump because my motor didnt produce enough.
Car: 89 IROC
Engine: 6.8 HSR N2O
As far as vacuum is concerned, I wish cam companies and "magazine" builds would list the idle rpm and vacuum at idle for various combos. Had one expert tell me a 256/260 @.050 HR cam on 113lsa in my 421 would operate power brakes. I am a little suspicious of that one. Variables like manual vs auto, idle rpm and what you consider acceptable all come into play. I had a combo that would operate the brakes ok when first applied but the assist would lessen as the brakes were re-applied. Like at a stop light or when inching forward. Some drivers can tolerate less assist than others.
Axle/Gears: 4.10:1
Sometimes I wish I would have gone with the 427, but then I look at the fact I just ran an 11.9, with a full tank of gas. A half second quicker I have to put in a roll cage, no thanks. 11.9 street car is fine with me.
UltRoadWarrior9
04-28-2020 10:39 PM
