Southern California Area Southern California Members.
Good luck passing smog
Old 12-06-2011, 01:53 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
The guy that just tested my GTA said they lowered the pass numbers 30% Dec 1, 2011. Looks like he was right.
Here are the pass numbers from Jan 2010
AT 15 mph AT 25 mph
HC CO NO HC CO NO
108 0.71 767 83 0.58 706
Here are the new numbers
76 0.50 537 58 0.40 494
I failed both HCs and the 15mph NO. I would have passed with flying colors at the old numbers.
This arbitary lowering of the allowed emissions is total BS.
Time to remove CA BAR, CARB and AQMD from the gene pool.
Old 12-06-2011, 04:01 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Good luck passing smog
If my car emits the same as it did at the last test (10/29/2010), I'd still smack those numbers down:
Results last test- 26, .01, 91; 19, .03, 35.
Of course, I did just jinx myself.
The only thing that was different then, than my current sig, is the torque converter.
But, when I test again 10/2012, I could be looking at tighter yet target numbers.
Bill
Last edited by Burnout91; 12-06-2011 at 04:03 PM. Reason: Tried to un-jinx myself...
Old 12-06-2011, 04:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
I cant believe you are getting such low results with that cam What does a stock L98 put out emissions wise? Figured with the cam you'd never get a clean exhaust.
Old 12-06-2011, 04:52 PM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Ditto, not as good as Bill but I'd do OK too.
(Edit I dunno what Bill has but think I have LT4 hot cam in it?)
Tested Oct. 25
I got 36, .09, 218; 50, .09, 195
I didn't do anything special before smogging, nothing to the car all year.
(I don't even know how it was even running then, because shortly afterward they found a hole in fuel pressure regulator, exhaust leak, fouled up plug, idle was off...)
Old 12-06-2011, 05:19 PM
injdinjn's Avatar
They might have different pass numbers for single cat/dual cat cars. Only way to tell is to take your last numbers and drop them 30%. Not what you put out, what their limit was.
Old 12-06-2011, 05:31 PM
Burnout91's Avatar
Engine: Modded L98
I had a LOT more problems passing, including a couple of failures, and higher numbers (higher emissions), when the car was stock!
The stock injectors and tune send the HC's off the chart.
A LOT of peolple don't believe the car passed, without some flim-flammery. But I just let the tech do his thing, while I innocently pretended to talk on the cell phone.
I really wanted to video the test, and post it, but the camera would probably have made the tech nervous as a pimp in church.
I think some of you 3rd Genners need to run a bigger cam, and a , uh, questionable intake
Bill
Old 12-06-2011, 06:41 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Maybe Kevin can really tune
Old 12-06-2011, 06:53 PM
injdinjn's Avatar
You better hope so, this GTA is bone stock and scans just fine.
And my crew chief is pretty good at tuning too.
Old 12-06-2011, 07:17 PM
injdinjn's Avatar
And this is what, the 2nd lowering of the numbers in as many years.
What are you gonna do when they lower it below what you emit now.
If BAR and CARB are not curtailed soon they will send these cars right to the junk yards.
You can take the "Oh I can pass" attitude all you want, but when you can't pass it will be too late.
Old 12-06-2011, 07:56 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Guess I better enjoy driving my car all next year since my smog isn't due till Feb. 2013. Five bucks I wont pass the next time.
Old 12-06-2011, 09:06 PM
Dyno Don's Avatar
Just checked my last #s
10 .00 199 11 .00 200
Doubt if they could get under that.
Old 12-06-2011, 10:26 PM
injdinjn's Avatar
Whats to stop them?
And every mile you drive that vehicle raises those numbers.
Old 12-07-2011, 12:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
They want everyone to drive a Chevy Volt.
Old 12-07-2011, 01:11 PM
Burnout91's Avatar
Engine: Modded L98
Are there any CARB approved hop-up parts available for that Chevy model?
Old 12-07-2011, 01:42 PM
radicule's Avatar
Car: 1991 Z28
Engine: Rebuilt .30 over 5.7 TPI
Transmission: TR400
Axle/Gears: 3:23
I trhink there is. Something to to do with Energizer Bunny.
Old 12-07-2011, 04:07 PM
rock861261's Avatar
They are really coming down on the older cars next year it will be a smog every year instead of every 2... it might be time to look for a 1996 and new engine replacement if we want to keep driving our cars
Old 12-07-2011, 04:44 PM
injdinjn's Avatar
One ahole in Sac has tried that 2 or 3 times beginning about 5 years ago, did someone finally get that bill passed?
Or buy a 75 or older and redo the suspension.
Old 12-07-2011, 04:46 PM
injdinjn's Avatar
Since they've already done two 30% reductions, how about 2 more?
New standards:
37 0.25 263 5 0.20 242
Burnout91 aka Bill: FAIL
JulieGTA: FAIL
Dyno Don: FAIL
It's not a politically correct test, you have to get all of them right.
Old 12-07-2011, 05:07 PM
rock861261's Avatar
As far as ive heard its passed the guys on ls1tech were just talking about it
Old 12-07-2011, 06:46 PM
Car: 1989 GTA
Engine: 369 TPI
I dont know if 16 volt batteries would pass CARB.
Old 12-07-2011, 06:48 PM
Car: 1989 GTA
Engine: 369 TPI
This state "Kalifornia" is insane. I believe we are all for clean air but this is going way to far.
Old 12-07-2011, 07:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Does sound insane...a vast majority of the cars in that state wouldnt pass...what would they do? Does this requirement actually cover older generations? How can you expect a car designed to 1 standard a few years ago, pass a new standard? Doesnt make sense. I can understand if thats a new requirement for 2012-2013 new vehicles that havent been out yet
Old 12-07-2011, 07:57 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Bone stock with 25 years of carbon buildup and stock injectors might be part of the problem?
When was the last time you changed the plugs, wires, cap and rotor? When I failed multiple times last year it turned out to be a bad cap and rotor. And yet the BLM's and INT's were showing just fine, too.
Are they going to give everyone $20,000 towards a new Chevy Volt? Thats about the only way I can afford a new "clean" car. Oh, I know, all of us tax paying citizens will just leave the state, and they can keep supporting the rest without our money.
Old 12-08-2011, 01:41 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
We are in the same boat trust me
Hopefully my car passes smog also
Old 12-08-2011, 12:38 PM
injdinjn's Avatar
And a bottle of Guaranteed to Pass and a 70-80mph trip to Victorville and back didn't work.
@Kevin all that has ~11,000 miles on it. The injectors are Bosch IIIs with about 6K on them.
FWIW these are my numbers
@15 96 0.34 548
@25 73 0.15 338
Failed both HCs and 15mph NO
Old 12-08-2011, 12:39 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Transmission: M6
Axle/Gears: 9" spooled 3.70
more reason to go ls
Old 12-08-2011, 12:50 PM
injdinjn's Avatar
The system sucks.
I have all the maintenance records on this car. It had oil changes and tuneups at normal intervals, it has just over 90K miles on it no leaks no oil use. If you can't put 100K on engine that has been properly maintained the smog numbers are BS. Are we looking at rebuilding engines every 25K.
And eventually the ls motors will be in the same boat.
I am not familiar with the actual wording but I think the Feds require the smog equipt to be warrantied for 100K, what good is that if the smog numbers are so low that a 60K engine won't pass.
Another thing I just noticed is that the AVG numbers are rising while the PASS numbers are going down.
Old 12-08-2011, 01:50 PM
Burnout91's Avatar
Engine: Modded L98
What does a new car blow (emissions wise)?
Old 12-08-2011, 03:58 PM
injdinjn's Avatar
Who knows, Don, Julie and Bills cars are recently rebuilt and 2 more 30% reductions and they will fail.
Old 12-08-2011, 05:15 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Question for all you residents of Nazifornia....Is there a cut-off year for no more testing of older cars? In Texas it is 24 yrs & older (at 25 yrs it becomes exempt) & testing is only in certain counties.
Old 12-08-2011, 08:53 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Whats to keep you guys from registering out of state?
Old 12-08-2011, 10:31 PM
Kevin91Z's Avatar
That costs even more money, PLUS you have to go to the referee to have it certified. No thank you.
Yes, any car 1976 or newer has to be emissions-certified. Any vehicle 1975 or older is exempt and does not have to be tested.
There's a provision in the law that says you have 10 days from the date of moving into California to get your vehicle registered here. So if the same cop sees your car with an out-of-state plate in 2 weeks time, he will pull you over and ask you whats up.
Old 12-08-2011, 11:44 PM
rock861261's Avatar
The refs are easy im just about done with my swap and I know them by name lol all you have to do is have emissions they dont even raise the car... they check the pcm and engine bay emissions and give you a smog check... one of the huge benefits is your car becomes what ever year engine you put in smog wise so next year as the smog every year law kicks in ill only have to smog it every 2 years... and they arent even that expensive I got mine a complete longblock with arp and scat internals for $2500 making 400hp
Old 12-08-2011, 11:45 PM
rock861261's Avatar
thats the way it used to be rolling exemptions however they stopped it a few years back and only make 75 and older
Old 12-08-2011, 11:50 PM
rock861261's Avatar
The state cant keep lowering the % because if you fail smog and your car isnt modified you can qualify for a test only center to do repairs and they pay for a certain amount. with an already bankrupt california thats going to end to and they will have to find a happy medium
Old 12-09-2011, 03:01 AM
JulieGTA's Avatar
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Bah.
Humbug.
Try changing your cats?
Old 12-09-2011, 04:19 AM
Burnout91's Avatar
Engine: Modded L98
Misery would like to have company, I suppose...
Old 12-09-2011, 08:57 AM
radicule's Avatar
Car: 1991 Z28
Transmission: TR400
Axle/Gears: 3:23
I'm going in for my third try to pass smog this Sat. Wish me luck. I will post the results.
Old 12-09-2011, 11:26 PM
injdinjn's Avatar
These cars are test only now.
I don't think you have ever read the fine print to qualify for the State paid repairs.
Old 12-09-2011, 11:32 PM
injdinjn's Avatar
I started this post to inform those who care how the govt is only there to force the individual citizen to support them and big business. In this case by making your car worthless and having to buy a newer car paying sales taxes and higher license fees.
Ostriches live in their own dream world.
Old 12-10-2011, 12:00 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
The State paid for my Camry to pass smog and it cost me only $25. I had to go to a Test only station and was unemployed at the time so I qualified for low income and test only. The catch is your can not be modified at all in order to qualify.
My IROC will never qualify for state assistance.
Old 12-10-2011, 12:37 PM
Car: 1989 GTA
Engine: 369 TPI
"My IROC will never qualify for state assistance."
Hey, get rid of that turbonator and it will be back to stock.
Old 12-10-2011, 01:34 PM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
Just tested mine this morning. Don dropped a rebuilt engine into it last spring...
_______HC Max / Meas_____CO Max / Meas____NO Max / Meas
15mph______88 / 88__________0.55 / 0.15______1097 / 579 Pass
25mph______71 / 62__________0.41 / 0.01_______927 / 703 Pass
*wipes forehead*
Old 12-10-2011, 02:49 PM
Car: 90 IROC-Z
Transmission: M6
The allowed is different....
Old 12-10-2011, 04:52 PM
Burnout91's Avatar
Engine: Modded L98
OK, here's a reference point:
2000 Silverado 1500 5.3L, 125K Mi., bone stock: (Max/Meas) 105/5, .60/.01, 992/11; 93/2, 1.03/.01, 852/12.
Looks like my car's a pig after all.
Old 12-10-2011, 06:01 PM
Dyno Don's Avatar
Damn...I thought this thread was about cheese & crackers.
Old 12-12-2011, 09:37 AM
radicule's Avatar
Car: 1991 Z28
Transmission: TR400
Axle/Gears: 3:23
Actually I did read the fine print. I just need 7 more people living with me to qualify.
Failed again:
HC Max 81 / Meas 18 CO .50 MAX / Meas .01 NOX MAX 537 / Meas 715
Old 12-12-2011, 10:58 AM
Dyno Don's Avatar
Just wondering if you cut the hole in the gasket on the right side where the exhaust goes into the EGR. I know we cleaned the solenoid and checked the wires.
Everything else looks good. Only the NOX failed.
Old 12-12-2011, 11:28 AM
radicule's Avatar
Car: 1991 Z28
Transmission: TR400
Axle/Gears: 3:23
Actually I'm going to set the timimg @ 4 BTDC. Someone else did that and it passed.
Old 12-12-2011, 08:45 PM
injdinjn's Avatar
They check the timing.
Quick Reply: Good luck passing smog
