ecm keeps blowing fuse
Old 12-04-2011, 04:05 PM
ROADKILL76's Avatar
Car: 1988 T/A
The other day my alternator went out while I was driving home so I kept going to try to make it there before the battery fully died, didn't make it, but I got a new alternator and charged the battery and now the ecm fuse keeps popping I've gone through half of my fuses trying to figure it out. The fuel pump is new and had it put in at a shop, but I'm stumped and need some help
Old 12-04-2011, 04:52 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: ecm keeps blowing fuse
its blowing because its drawing more amps than the fuse can handle. the ecm power circuit is either grouning out on something, or something is wired into it that shouldnt be.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
btw, were in arlington are you?
Old 12-04-2011, 05:00 PM
ROADKILL76's Avatar
Car: 1988 T/A
Central Arlington ,the closest intersection is Arkansas ln and fielder rd, it hasn't given me any problems before it died
Old 12-04-2011, 05:02 PM
travis401's Avatar
Car: 91 Camaro RS
i used to work at ricks autobody off arkansas and cooper. its possbile that when the alt died, it took something else out with it thats causing the issues.
you should check out nttga.net, its a 3rd gen group here in dfw.
Old 12-04-2011, 05:07 PM
ROADKILL76's Avatar
Car: 1988 T/A
That's not far away at all lol, what all wires go to the positive battery terminal? I just noticed some frayed wires
Old 12-04-2011, 05:12 PM
travis401's Avatar
Car: 91 Camaro RS
ecm gets its power from the pnk wire with black strip thats on the c1 plug at position a8. the VATs module and ESC module also get their power from the ECM fuse.
Old 12-04-2011, 05:13 PM
ROADKILL76's Avatar
Car: 1988 T/A
No vats on mine
Old 12-04-2011, 05:58 PM
ROADKILL76's Avatar
Car: 1988 T/A
The fuse thats popping is the inline one by the battery
Old 12-04-2011, 06:09 PM
travis401's Avatar
Car: 91 Camaro RS
that fuse is for the battery voltage for the ecm and the fuel pump relay. can you check to make sure the relay isnt fried? or that the wire isnt melted and grounding out on anything
Old 12-04-2011, 06:14 PM
ROADKILL76's Avatar
Car: 1988 T/A
I just replaced the relay today
Old 12-04-2011, 06:23 PM
travis401's Avatar
Car: 91 Camaro RS
and the fuse started blowing after that? if thats the case id pull the relay off and see if it stops blowing. if it does then you found the problem
Old 12-04-2011, 06:35 PM
ROADKILL76's Avatar
Car: 1988 T/A
I found it its the relay harness
thunder57
11-07-2015 02:28 PM
AmorgetRS
09-28-2015 09:33 PM
SS-EXPRESS
09-28-2015 09:14 AM
lanceflame44
09-25-2015 12:28 PM
90formulaVortec
09-03-2015 09:26 AM
Quick Reply: ecm keeps blowing fuse
