dupli-color automotive paint
Old 11-29-2011, 04:34 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
why do people use tractor paint instead of this which is designed for a car,is reasonably priced and available at the local parts store?just wondering.
Old 11-29-2011, 09:41 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: dupli-color automotive paint
Cost and Tractor paint is a single stage, as oppose to the dupli color which is a BC/CC or Tri-coat.
Old 11-30-2011, 07:00 AM
jim91gta's Avatar
Car: 1991 GTA
Engine: 5.7
Dupli-color is lacquer paint. it will dull.
Tractor paint etc. will also adhere to you current primer/paint where laquer will need it's own primer.
Dupli-color will also cost morewhen you are done than if you went with a low end urethane paint.
Old 11-30-2011, 09:26 AM
Badazzbird's Avatar
Car: 1987 firebird custom restomod
Engine: 2.8 v6(350 swap comming soon!!!)
Axle/Gears: Stock
What type of duplicolor paint are you refering to? I can definetly say that there vinyl paint is excellent, my interior was originally grey and I completely redyed it black. Worked great and looks better than stock!!!
Old 11-30-2011, 03:10 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the duplicolor line of "paint shop" paint found in most auto part stores. its a lacquer based paint, which is harder to spray, and harder to upkeep.
Old 11-30-2011, 04:27 PM
Badazzbird's Avatar
Axle/Gears: Stock
Oh okay, never used that before went to sherwin Williams to get my paint. Took my own paint code and had them mix it for me. Really good quality paint and I'm cool with the guys that work in the one near me so they even let me in after hours which was really cool!!
Old 11-30-2011, 04:33 PM
travis401's Avatar
Car: 91 Camaro RS
its supposed to be for the "budget" minded diyer. they normally have quart cans for like $20 on the shelf. i have though about using the matte clear they have though. just need to find out if the clear is compatable with a bc/cc system.
Hotrodboba400
12-10-2019 07:07 PM
carid
Sponsored Vendors
09-10-2015 09:33 AM
TheExaminer
09-06-2015 11:40 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: dupli-color automotive paint
