L98 rebuild
Old 11-28-2011, 12:19 PM
ozzy74's Avatar
Engine: rebuilding L98
Transmission: 700 R4
L98 rebuild
Im rebuilding a L98 and want to try an get 300hp out her when done...not looking to spend a fortune and already have headers to go on...any ideas...thanx
Old 12-03-2011, 04:44 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: L98 rebuild
If your talking about FWHP, that should be as easy as falling off a log. Quality rebuild parts, have a little pocketing porting/port clean up done on the heads when you're having them worked on. A ZZ4/LT4/LT4 Hot cam, which can be found used in good condition for a song, ported plenum and a cat back with your headers should make you golden. Now, if you want 300 RWHP, you might wish to rethink your budget. That's probably going to require serious, (expensive) head work or a set of nicely built Vortecs, bigger injectors and upgraded intake components.
Old 12-03-2011, 11:21 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: L98 rebuild
First question, what is your budget?
Old 12-04-2011, 12:25 PM
ozzy74's Avatar
Re: L98 rebuild
around 2 grand budget on engine....new to the rebuilding thing..looking for 300 rwhp
Old 12-04-2011, 12:54 PM
ozzy74's Avatar
Re: L98 rebuild
budget is around 2 grand for engine...new to the rebuild game....looking for 300 rwhp
Old 12-04-2011, 07:58 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Re: L98 rebuild
Ok, here is my next question. Does the engine need a rebuild at this time? Is it burning oil? Have you done a compression check to see if the rings are sealing? If it's not burning oil and it's sealing good I wouldn't waist money on a rebuild. If you have to rebuild it you can get a decent rebuild kit from summit for a few hundred bucks. The biggest thing you will be spending money on is the machine shop. Depending on the condition of your parts you should be able to reuse the crank and rods. So you are looking at new pistons, rings, cam (if it's not a roller), and bearings. I would recommend you get David Vizards book http://www.amazon.com/Build-Chevy-Sm...3050111&sr=8-4 It is full of great tips and advice. For 300 hp at the crank you could just switch to Vortec heads and you would be right there.
Old 12-04-2011, 08:23 PM
ozzy74's Avatar
Re: L98 rebuild
the crank is scarred a bit...bearings are worn...one cylinder wall is scarred also from a piece of the piston that broke off....would my intake fit with the vortec heads....its a tpi intake ...buddy of mine has a set for vortec heads that he would sell me...
Old 12-04-2011, 09:01 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Re: L98 rebuild
No the stock TPI intake will not fit. You have to buy the Vortec specific one from Edelbrock. Try and find a used one though in the classifieds on here or ebay. Also the stock springs on the Vortecs don't like a lot of lift, they have retainer to guide issues. But you could run the crane compucam 2032 or something along that line with those heads and make over 300 at the crank no problem.
Old 12-07-2011, 06:13 AM
ozzy74's Avatar
Re: L98 rebuild
should i get different injectors?
Old 12-07-2011, 01:29 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: L98 rebuild
buy another l98 short block that is in good running condition. check tolerances on the crank, rods, etc and replace the bearings or have the crank reground. It's better to start with an undamaged block and go from there. I bought a $300 "mystery engine" from another 91 z and it turned out to be a gmpp crate motor. The rebuild on that cost me $1200 to have the crank polished and throw in a cam. I got lucky and it came with forged pistons already but for 2 grand you should be set.
Old 12-07-2011, 08:43 PM
ozzy74's Avatar
Re: L98 rebuild
the engine was running fine when i tore it down....cylinder damage is really minimal...gonna take the bottom end to a machine shop and get the block fixed and dipped and get my own crank worked on...no need for another block
Old 12-07-2011, 09:09 PM
theNMBR27's Avatar
Re: L98 rebuild
I wanted at little down time as possible before winter. Have you thought about a cam yet?
Old 12-07-2011, 09:22 PM
ozzy74's Avatar
Re: L98 rebuild
crane compucam 2032....car is in storage for the long canadian winter...lots of time to ask questions and get different opinions....was wondering bout injectors...how big can i go?
Old 12-07-2011, 09:24 PM
theNMBR27's Avatar
Re: L98 rebuild
If you dont plan on making more than 350 hp 24 lb injectors should be fine
Old 12-07-2011, 09:40 PM
ozzy74's Avatar
Re: L98 rebuild
stock bottom end, vortec heads, edelbrock intake, chopped out air box{only filters there now}, airfoil, shorty headers ,no emission test needed so no converters either straight exhaust to the flowmasters and programmed chip...sowhat im saying is im not sure what kind of horse power all that will make...lol..anyone else have that kind of set up?
FormulasOnly
07-23-2018 08:47 AM
sleprock
Interior Parts Wanted
10-03-2015 11:01 PM
hartsmike
10-02-2015 07:11 AM
Derrick86
10-01-2015 05:12 AM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
Quick Reply: L98 rebuild
