PBR Rear Brakes
Old 11-22-2011, 12:10 PM
BlueWrath92's Avatar
Car: 92 Camaro RS
Axle/Gears: 10 Bolt 3.42 Posi
PBR Rear Brakes
I just got a 92 z28 disc rear end 3.42 gears 10 bolt. I cannot find a 1LE PBR rear brake kit for the life of me. do I have other options?
Old 11-22-2011, 12:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: PBR Rear Brakes
What kit are you looking for?
JamesC
Old 11-22-2011, 12:51 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: PBR Rear Brakes
http://www.andyz28.com/3rdGen/reardisc.html
for the mounting brackets.
Old 11-22-2011, 12:58 PM
JamesC's Avatar
Re: PBR Rear Brakes
If you want an all-inclusive kit, the following, though pricey, should do the trick:
http://www.flynbye.com/catalog/i10.html
EDIT: I completed the swap a number of years ago. The following write-up contains info and part number that may be helpful if you decide to 'piece' parts together:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Old 11-23-2011, 12:56 AM
Car: 92 Camaro RS
Re: PBR Rear Brakes
Thanks James, that kit is is exactly what I need and a good price for brand new components. If I cannot find someone selling there old stuff I am getting that kit. Camaro Heaven quoted me at $3,500 for a USED OEM rear PBR set .
Old 11-23-2011, 10:30 AM
Car: 92 Camaro RS
Re: PBR Rear Brakes
I found this kit, its not PBR but its a little cheaper
http://www.autopartswarehouse.com/sk....html?loc=Rear
and they also had this Kit
Im not sure of the differance between the two, and between those and the PBR, this site says they are a direct fit. any input?
Old 11-23-2011, 11:40 AM
Car: 92 Camaro RS
Re: PBR Rear Brakes
-would I need this kit:
http://www.flynbye.com/catalog/i182.html
-or this kit:
http://www.flynbye.com/catalog/i24.html
-for this application:
http://www.flynbye.com/catalog/i1.html
that second kit says it "may need spindle modification", im not sure what kinda modification they are talking about.
Old 11-23-2011, 12:37 PM
Engine: Lb9
Transmission: M20
Re: PBR Rear Brakes
I contacted the pbr america rep about five years ago and they had the new calipers as a set with the ebrake brackets for $350.
Old 11-23-2011, 12:40 PM
Twin_Turbo's Avatar
Re: PBR Rear Brakes
The rear conversion is for a drum rear, you need the brackets for a disc rear 10 bolt. The other 2 links are brackets for the front which require spindle mods and a complete front kit You're looking for a kit for the rear right???
Old 11-23-2011, 01:36 PM
Car: 92 Camaro RS
Re: PBR Rear Brakes
Yes Im looking for a kit for the rear, your right I dont need a conversion kit... I am unsure of those brackets because they say 12" rotor conversion for rear. Here are some questions I have:
-what are my options for direct bolt-ons with my rear and 15" wheels (size of rotors)?
-Will C4 or C5 brake kit mount direct fit? If so are they any better?
-will LS1 brakes fit direct?
Thanks tunedperformance I will give them a call
Old 11-23-2011, 01:38 PM
Twin_Turbo's Avatar
Re: PBR Rear Brakes
the 12" rotor kit used c4 corvette rotors, with the brackets it's a bolt on deal. What are you running on the front?
Old 11-23-2011, 02:11 PM
Car: 92 Camaro RS
Re: PBR Rear Brakes
I have the stock brakes in front right now that I plan on replacing in the future along with a front end rebuild. But right now I have a drum rear on the car, I have the 92 z28 rear sitting in the garage waiting for brakes.
ZMWojnar
Brakes
05-12-2019 10:43 PM
Eric-86sc
04-03-2016 03:52 PM
SpaniardV6
Brakes
19
09-07-2015 03:04 AM
kyleb24
08-15-2015 08:24 AM
Quick Reply: PBR Rear Brakes
