383 First Fuel Injection TPI Need Computer System
Old 11-06-2011, 07:44 PM
L98KR1989's Avatar
Car: 1985 Trans Am, 89 Firebird Formula
Engine: 85 305 Carb, 89 350 TPI
Transmission: 85 T5, 89 700R4
Hey Guys i could use some help I'm in the process of building a 383 motor with the first fuel injection TPI system for the intake. But im not to sure on a good computer system to put on it. I need something completely programmable. and the systems FIRST offers are all $2000+ there has to be cheaper solutions that will work. I appreciate any help on this matter.
Old 11-06-2011, 08:04 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 383 First Fuel Injection TPI Need Computer System
www.dynamicefi.com ebl p4 " rbob"
Old 11-06-2011, 08:15 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
0411 PCM with a harness from eficonnection.com. Very capable unit and cheap for the DIY'er. Perfect for a street 383. That's what I'm running on one of my 383 TPI engines. Wouldn't go any other way, except maybe 24x coil on plug next time.
Old 11-06-2011, 10:05 PM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
http://www.larryselectricsite.com/st...hp?productid=2 <-- this. You can have a custom prom burned for it. This is definitely the cheapest way to go I think. I've searched all over, I can't find anything that beats this deal.
Old 11-06-2011, 11:06 PM
Engine: Lb9
Transmission: M20
If you want a v6 memcal, no knock and poor lhm
Old 12-17-2011, 12:09 AM
L98KR1989's Avatar
Sorry guys I got really caught up with work this past month i looked into the dynamic and i like what i see i do know some engine guys who could help me build all the tables i need in the comp. even without them it seems do able by myself.
tunedperformanc. If you want a v6 memcal, no knock and poor lhm? What did this go to your dynamic system or anothers?
Old 12-17-2011, 12:36 AM
Engine: Lb9
Transmission: M20
I was referring to larry's electric remanufactured v6. Memcals made too v8.
Old 12-17-2011, 02:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What is wrong with a stock ECM like a '730 SD setup with a custom harness to run standalone like the First setup would be?
Plenty of us making good power on strokers with reprogrammed stock ECM's
ECM $50+
Harness $300
Tuning hardware $200 ( real time on the fly tuning )
Tuning software free ( $30 donation optional )
Check out what the gurus in Tuning Dept get up to
https://www.thirdgen.org/forums/diy-prom/
https://www.thirdgen.org/forums/dfi-ecm/
Old 12-17-2011, 02:04 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Fast EZ efi $850
Old 12-17-2011, 09:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Steve Mack
Fast EZ efi $850
IIRC; no electronic spark control
Have to run vac advance dist ( or fixed advance curve )
jhawkeye
05-25-2022 06:33 PM
midge54
12-27-2019 04:14 PM
9192camaro
16
02-03-2019 12:21 AM
84z96L31vortec
08-20-2017 12:16 AM
Fast355
12-02-2016 06:33 PM
Quick Reply: 383 First Fuel Injection TPI Need Computer System
