DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
ecm noob question?! i need help asap
Old 10-27-2011, 12:25 PM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
hi,
i had a custom chip for bigger injectors(i don't remember if i pulled a stock one out or not), now i have stock injectors, so i pulled out the custom moates chip.
question, do i need a stock memcal/(or prom?) and does it go where the custom one was? or is it built in somewhere and nothing goes in this spot?
Old 10-27-2011, 12:50 PM
89shane350's Avatar
Re: ecm noob question?! i need help asap
and if so whats the prom number i need to put in? 5.7 89 tpi auto
Old 10-27-2011, 12:55 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
You need to replace the PROM with a stocker or a correctly tuned chip.
Old 10-27-2011, 12:59 PM
89shane350's Avatar
ok great, i was scared because my car wont start lol, ok i found out that i think i need "9303ANYJ"prom, is there another name for this? i cant find it on google as far as purchase goes...
Old 10-27-2011, 01:40 PM
89shane350's Avatar
ok if the part number for the 5l is 16060836 what is the 5.7??
Old 10-27-2011, 01:47 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if you are using the ecm in the picture a 1227165 maf you can use any 86-89 v8 350 memcals, the 89 is the best no cold start programing.
Old 10-27-2011, 01:49 PM
89shane350's Avatar
Originally Posted by tunedperformanc
aujp 16151348 5.7 tpi 700r4 90-92, try ebay or tpiparts
mines an 89, yea i was looking at those sites,l but wanted to see if i could find the oem one first, do you have the 89 PN by chance?
Old 10-27-2011, 01:51 PM
Aaron_SK's Avatar
He needs a MAF PROM not MAP.
Also he's an '89 so he needs that specific year because it is the only one GM made with the MAF and without 9 injectors.
ARAP should be the right BIN iirc.
Old 10-27-2011, 01:56 PM
Aaron_SK's Avatar
Can't edit posts, ARAP is the Vette BIN. Would run but have too hot of a timing table. Try looking for AUJL.
Old 10-27-2011, 02:03 PM
Engine: Lb9
Transmission: M20
yes arap might cause a iron head to ping,
https://www.thirdgen.org/forums/engi...80-memcal.html
or if you find a 305 one 86-89 I will reprogram for fairly cheap $6e mask
if you have a v8 memcal all you would need is a chip burned togo into your moates g1, let me know if I can help !!
Old 10-27-2011, 02:06 PM
89shane350's Avatar
is it 16129303? i cant find one for sale darnet,
Old 10-27-2011, 03:19 PM
89shane350's Avatar
Okay, I'm an idiot, the old chip as attached to the Moates! lol
So here is my next question, it has markings on it but this is a replacement ecu, can you verify if its the right chip? i looked up 2 codes one said 5.7 and the other said 5.0
silver tab; 4218 AUJL 0577
under that 014 69300 b9416AD
next chip;16072665 91 07
last chip; 16133420 91 30 printed twice
Old 10-27-2011, 03:22 PM
Aaron_SK's Avatar
AUJL is the correct chip, read my post a bit back in the thread.
Old 10-27-2011, 04:00 PM
89shane350's Avatar
ok thank you guys so much! runs good now
BlueIroc-Z
06-09-2019 03:22 AM
dutch930
09-11-2015 06:58 AM
ezobens
DIY PROM
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: ecm noob question?! i need help asap
