Will a Chevy or Pontiac TH350 bolt to a Iron Duke?
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
My 82 fbird has the Iron Duke with the Th200 and its slipping horribly, I know I can pay for a rebuild but for the price I kinda want to put something stronger behind the duke?
Summit down the street from me sales there reman 350s for nothing with warrenty but I have no idea about bolt patterns?
Thanks for any info
Thanks for any info
Received 1,668 Likes
Re: Will a Chevy or Pontiac TH350 bolt to a Iron Duke?
If memory serves, that thing has the BOP pattern. So a BOP 350 should fit without much effort.
Post a pic of the BH from the front, where it would meet the engine if installed, and we can maybe identify the bolt pattern.
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Depends on year. Early Duke's had an SBC pattern, later ones had the 60* Metric pattern.
If my current transmission pan says metric on it would that clarify the 60* metric pattern?
and sofakingdom you mean take a pic of the block with the transmission off showing the flywheel?
Since the trans is dead and you therefore already have it out, take a pic of it from the front, where it bolts to the block. Pretty easy to identify the pattern.
I dont have the trans out it will be once i can get it to a friends house with a car lift so much better than do it at my place i dont have flat ground anywhere
and aaron goin with this source http://en.wikipedia.org/wiki/List_of...using_patterns
my starter being located on the left side if viewed from the fly wheel it looks like cv8
If it looks like the Chevy pattern then a Chevy trans should fit it.
Just gotta make sure which side the starter is on; driver's side, or pass side. Not sure what that other "left" stuff is saying.
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
25, bolt, chevy, combo, duke, fit, install, iron, pattern, pontiac, reansmission, th350, tranmissions, trans, transmision, transmissions, vega
