12 bolt
Old 10-17-2011, 08:39 PM
84TransAm383's Avatar
12 bolt
Im looking to buy a new 12 bolt or 9 inch but had few questions hopefully someone can answer.
The strange only accept 97-02 brakes and want to no if i can just by the calipers and all from pepboys or something and slam em on my 84.
Also the rear is a inch wider and wanted to no will my rims and tires still fit or will they stick out and hit the wheel wells. They 15x8 with 4 inch backspace
Any info on the swap will be helpful in all ways
Old 10-18-2011, 11:07 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: 12 bolt
You can buy the rotors/pad/calipers from a parts store, but you'll be missing the backing plates and parking brake drum. I bought mine from this guy, and everything worked out well:
http://www.ebay.com/itm/98-02-Camaro...item48416d1805
Offer him around $150, that's what I did. You'll still need to come up with your own parking brake cable solution. Here's what I was able to do with the LS style cables and our stock cables.:
https://www.thirdgen.org/forums/brak...-ls1-swap.html
The extra inch won't make much difference and you probably won't notice.
Old 10-18-2011, 10:14 PM
Re: 12 bolt
i wasnt really worried about the ebrake system. Is it ok to leave it unhooked or does it have to be. It hasnt been hooked up on my 7.5 in three years
Old 10-18-2011, 10:16 PM
Car: '91 LS6/T56/9"
Engine: LS6
Re: 12 bolt
It's not an e-brake, it's a parking brake and it should be used every time you park regardless of your transmission.
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
Numbah-1
09-12-2015 08:57 PM
Jlanz55
09-06-2015 07:28 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: 12 bolt
